06-16-2010, 07:02 AM
CGVES - '99 Chrysler Grand Voyager ES
Hello from Norway
Hi everyone (and excuse my English, it hasn't been exercised for a few years)!
I am new to this whole eco-driving thing, although I am and have always been interested in different kinds of optimization. Only earlier it have been in terms of power and performance (not owned any fast cars though, mostly this manifested itself in tuning and modding mopeds when I was that age). I am not sure if I am going to do any mods (at least not any heavy mods) to my car now either, but I am interested in the subject nonetheless
My girlfriend and I just bought a 1999 Chrysler Grand Voyager, equipped for wheelchair transport (my gf is the one in the chair). This combination of a heavy, lesser motorized car (weighs about 2300kg/5070lbs with us two in, 2.4L, 4speed automatic), which rides high with a soft suspension (about 5cm/2in higher than factory due to lowered floor/air suspension) does not exactly send me on a "power trip", so i found that honing my driving skills for maximum comfort and economy is the way to go to keep things interesting.
I have not recorded any data on fuel usage so far as this car is new to us, but I will keep records from now on. I have also ordered a ScanGauge II, can't wait to get it (I'm a gadget freak!).
Unfortunately, the roads around here (as in most parts of this country) are rather tight, twisty and hilly, and I will probably never see real awesome MPG's, but at least the hills and turns make for a more exciting drive
We're going on a road trip to Paris this summer, though, it will be interesting to see the difference in fuel economy on the continental European highways vs Norwegian roads.
Any tips or comments? Please post
06-16-2010, 10:04 AM
aero guerrilla
Hello, welcome to EcoModder
Yeah, everyone says that in the beginning
Try engine braking on the downhills. This should cut the fuel, letting you coast almost for free.
A grille block and a block heater since you live in a cold climate.
Remove any racks or railings from the roof, those hurt bad.
Before your trip you should try a few aero mods, like smooth wheel covers or a bellypan. These are hard to notice, so easy to get past your Significant Other Rear wheel skirts and/or a mini-Kammback would help noticeably.
06-16-2010, 03:10 PM
Thanks for the welcomes and tips
Originally Posted by Daox
I'm sure you can do a few mods to it. Airing up the tires to max sidewall is quite an easy one.
I had them to something in between the car manufacturers specs and max sidewall, but I have maxed them out now They are brand new Michelin Energy Savers, so they have rather low rolling resistance.
OK, I have to admit, I just came home after visiting the hardware store, I bought some sheet metal and something to cut it with Took a look under the car, and there, about a foot rear of the front tires, I found mudflaps, almost 20% of the car width EACH, hanging almost to the ground. I figure they are there to protect the floor (which is plywood). Also, there is a couple of transverse beams supporting the plywood (which is a little more than a foot wide, from the "frame beam" out), behind the mudflap. And if I fasten a little sheet metal, from the mudflap and about 3 feet back, this will cover it all, and there will be a flush surface between the side skirt and the "frame beam" instead of a ground-sweeping mudflap, a 3 inches deep hole and a couple of transverse beams And the wood should be at least as good protected as well.
Engine braking and DFCO is a well known concept already Also trying to learn how much throttle I can give it in different speeds without the lock-up releasing. Can't wait for the ScanGauge to get some precision to this.
The car is equipped with a block heater, but unfortunately I don't have access to any outlet where I park. The car also has a Webasto gas heater, but that doesn't save much fuel, I guess Roof racks are long gone, but the rails are still there. Haven't looked into removing them yet.
06-16-2010, 03:35 PM
aero guerrilla
I don't know if you've seen Orange4boy's thread on using a switch to take control over the torque converter?
Freezing the Slushbox. Torque Converter on-demand lockup switch.
Geez, I can't imagine how good it was a few years ago!
06-17-2010, 10:47 AM
I was about to do it on my last car ('92 Volvo 960 3.0) along with semiautomatic control of the tranny, but not for eco driving purposes, more for the fun of the project itself.
I won't dare it on the Chrysler though, since the "slushbox" in that one is controlled by a fuzzy-logic ECU that complains loudly if something messes with its measured and controlled slip of the converter and tranny clutches. A converter lock-up switch will most probably function as a limp-home-mode switch, from what I've heard and read. Those transmissions are fragile and prone to trouble enough as it is
A good idea nonetheless
