Hi,
I've been busy the last couple of days but wanted to share this baseline, performance data:
The benchmark protocol was to reach cruise control speed, confirm with the GPS and then reset the trip meter. The raw data:
direction MPG speed distance
E 65.3 50 5.2
W 67.5 50 5.3
N 58.3 60 8.1
S 64.1 60 8.2
N 55.3 65 7.9
S 54.2 65 8.2
E 57.1 70 14.3
W 47.9 70 13.2
E 51.6 75 10.5
W 47.1 75 14.3
S 40.0 80 11.7
N 39.4 80 11.7
To put things in perspective, our NHW11 gets 39 MPG at 75 mph:
This chart includes some high speed, NHW20 data gathered on a hot day, 90F. Sad to say, my 80 mph data was gathered at 62-64F, my first opportunity to run the test. This is a stock ZVW30 with none of our usual hacks running Shell 87 E10, the dealer tank.
I was also able to do some hill climb tests:
It looks and sounded like the maximum, sustained hill climb speed is between 77 and 84 mph. The maximum sustained speed is the engine-only powered speed that does not draw on the traction battery energy. For example, we also have an older, NHW11, 2003, and earlier testing revealed that the worst fuel consumption on a hill climb corresponds to the 'all engine' power up the hill:
Bob Wilson
2019 Std. Range Plus Model 3 - 134 MPG3 || 2014 BMW i3-REx - 117 MPGe, 39 MPG
JuiceBox 40 Pro (240 VAC, 40 A), KHONS portable (120-240 VAC, 12-32 A)
Retired engineer, Huntsville, AL (
five times AutoPilot saved.)
