09-22-2021, 08:47 PM
#121 (permalink)
I (nearly) finished reassembling Aerocivic's suspension, and replaced the rear brake shoes while I was at it, even though the ones on it looked like they had at least half of their life left. I'm taking it in to a shop to have the main bushings in the rear trailing arms pressed in. Temporarily, the driver side bushing with the broken bolt is actually welded to the frame of the car on one side. Currently waiting on one brake line hose (I guess I can just reuse the old one, it seemed in ok shape) and then to bleed the brakes before I have the bushings done and get an alignment. After that, it will be mechanically ready for a road trip.
I think there might be a very slight exhaust leak somewhere, but that can wait. The car has 100% new fluids and every bushing and suspension component, aside from the front shocks, is new.
Next task will be putting the interior back together (I had some of the trim pieces off for cleaning them in the bathtub), and wiring up the new MPGuino color touch, courtesy of abbalooga, and putting some test miles on it.
The Following 3 Users Say Thank You to Ecky For This Useful Post:
09-24-2021, 05:45 PM
#122 (permalink)
Decided to do something about the rear visibility. After polishing, I started washing the rear window, and noticed there might actually be a pretty handsome car underneath the accumulated moss and dirt and tree sap and sun damage...
09-24-2021, 07:29 PM
#123 (permalink)
While I was thinking about visibility, I decided to put some camera mirrors on Aerocivic. This isn't going to be their final form, but it'll get me across the country more safely at least. I also replaced the speakers with some new Pioneers I had in my spare parts bin while I had the doors apart.
09-25-2021, 12:18 AM
#124 (permalink)
マット
No antique plate?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
09-25-2021, 12:57 AM
#125 (permalink)
High Altitude Hybrid
Originally Posted by M_a_t_t
No antique plate?
I don't know about Vermont, but in Colorado an antique (collectors) plate means you can only drive it a certain amount of miles per year. That's what makes them cheaper, because they're for a show car you don't hardly drive.
09-25-2021, 06:27 AM
#126 (permalink)
No antique plate?
It'll be getting a Michigan plate before long anyway. I'll look into my options there. There may be some opportunity for a neat vanity plate.
09-25-2021, 05:17 PM
#127 (permalink)
Took Aerocivic on a short drive. It has considerably more power now - from the tuneup I suppose? The mirror cameras also work great. Currently the car is just aligned based on the best I could do with a measuring tape, but it drove fairly straight.
At ~50mph I was seeing as high as 95mpg, but the mpguino isn't calibrated yet so take that with a grain of salt.
09-27-2021, 09:04 AM
#128 (permalink)
Turns out you can't swap the CEL and SRS bulbs with LED. There's a constant low current which is enough to keep these bulbs lit, and they end up being dim or bright, rather than ever turning off.
09-27-2021, 09:26 AM
#129 (permalink)
Focused on MPG
License Plate
Hopefully they will allow 7 letters/numbers...: AEROCVC
Staying Focus'd on MPG
The Following 2 Users Say Thank You to ECO-AKJ For This Useful Post:
09-27-2021, 09:35 AM
#130 (permalink)
You need a shunt resistor to bias that idle voltage
