Old 09-27-2021, 09:45 AM   #131 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by ECO-AKJ View Post
Hopefully they will allow 7 letters/numbers...: AEROCVC
Great call! I bet I can get that one.
You need a shunt resistor to bias that idle voltage
I don't mind putting the incandescent bulbs back in, but any chance you can tell me a little more about what's going on here? Why just those two and not any of the others?
Old 09-28-2021, 09:43 AM   #132 (permalink)
Can't offer a reasoning other than the light might be monitored for failure: if it changes the voltage on the circuit and perhaps causes another warning light to work like the SES light on my VW which is odometer based. You probably could even use a different colored led biased backwards or a common cathode multi colored so normal is green and failure goes red and the mix would be orange.
Ecky (09-29-2021)
Old 09-30-2021, 09:07 AM   #133 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
That's correct. I expect to be on the ground in Michigan no later than 3-4 weeks, so I need to get the rear suspension at least put back together before then.
Well darn, you move to Michigan just months after I move away.
Just caught up on the thread, nice progress on the Aerocivic!
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
Ecky (09-30-2021)
Old 09-30-2021, 09:21 AM   #134 (permalink)
Picked up an undented hood locally for $25. Only problem, it has a hole cut in it for a turbo hood exit, so I'm going to try and weld some sheet metal and sand it smooth, then paint it white. The current hood is pretty rough.
Old 09-30-2021, 02:23 PM   #135 (permalink)
It's on the right [left] side for a '57 Chevy ring sight?
Old 10-01-2021, 08:26 AM   #136 (permalink)
Can't say I understand.
On these older Civics, the engine spins backwards compared with most other engines. The engine is transverse, on the driver side of the bay, and the exhaust comes down in front of the engine and runs under the oil pan. I'm sure there were packaging advantages when you had a carburetor and filter on top of the intake, but to me it made no sense in 2005 when Honda was still selling that engine series.
Old 10-01-2021, 10:17 AM   #137 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
I think that might've originated in the early days of Honda. The master cylinder on my 75 is on the right (passenger) side even though it's LHD. There is no way the master would fit on the driver side because of how close the engine is to the firewall. Since it was originally RHD they probably just stuck with that orientation. I think the k series engines are on the 'correct' side.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 10-01-2021, 11:52 AM   #138 (permalink)
My error, it's a blade sight. The ring sight I remembered was a custom add-on.
https://i.pinimg.com/originals/90/6e...162e59d938.jpg
Ecky (10-01-2021)
Old 10-01-2021, 09:09 PM   #139 (permalink)
It's tough welding sheet metal this thin! Looks like the heat warped it a bit around my weld. It won't be perfect, but it'll do until I can find something a little nicer. Maybe I can come up with a carbon fiber hood somewhere...
ID:	31325   Click image for larger version
ID:	31326   Click image for larger version
ID:	31327   Click image for larger version
Daox (10-02-2021)
Old 10-02-2021, 05:30 PM   #140 (permalink)
