Old 10-11-2012, 08:04 PM   #81 (permalink)
I have now glued another 16" onto the main chassis piece, making it ~8'-6" long and the total glued together is ~10'-6" long. Only about 3 feet left to glue! It now includes about 1/3 of the rear wheels:
The last picture shows the rear bumper and the trailing piece of the main hatch door. The bumper is only a bit wider than the PhlatPrinter 3 -- it is a little over 3'-6" wide.
I've purchased the *last* 16 sheets of foam that I need and I am cutting them as rapidly as I can, to stay ahead of what I need to continue the gluing. I also bought two bundles (10 pieces each) of 16' strapping and a box of galvanized screws to construct the frame from the tarp to keep things dry without having to cover and uncover it all the time -- the taller it gets, the harder this gets.
aerohead (10-13-2012), Christ (10-23-2012)
Old 10-11-2012, 08:21 PM   #82 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
This is the coolest thing. I can't wait to see it all come together. I really like how the underbody slopes up in the back. Should make for really good airflow
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
The Following User Says Thank You to HydroJim For This Useful Post:
NeilBlanchard (10-12-2012)
Old 10-11-2012, 09:23 PM   #83 (permalink)
All-electrics are not my cup of tea, but that's a pretty interesting project.
Old 10-12-2012, 10:33 AM   #84 (permalink)
I'm hoping for a range of 300-400 miles, so it will hopefully be an all-electric that could work for almost all people, I think.
Old 10-12-2012, 11:02 AM   #85 (permalink)
TheCav - '04 Chevy Cavalier LS
Wow 300-400 miles would definately get you some sponsors. It is great to see something like this coming together. GL I will be tracking this.
Old 10-12-2012, 12:15 PM   #86 (permalink)
HydroJim's Avatar
What kind of batteries are you using? 300 miles is highly impressive. you could always create some sort of add-on generator for road trips, but I guess that would take away from your all-electric plans.
Old 10-12-2012, 02:55 PM   #87 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
This is so cool and amazing to watch. Any comments from your neighbors regarding the big blue monolith?
-Terry
The Following User Says Thank You to Tango Charlie For This Useful Post:
Christ (10-23-2012)
Old 10-12-2012, 10:00 PM   #88 (permalink)
Mileage-wise it's OK, but I'd still be concerned about recharging time.
Old 10-12-2012, 11:31 PM   #89 (permalink)
The efficiency will (hopefully) come from having very low drag. The pack I was planning on is ~55kWh lithium, and if it can consume between 100-150Wh/mile, then it should be 325-400+ miles on a charge.
Instead of just sitting overnight, it will be charging while it sits -- no problem.
Yes, I have now talked to several of my neighbors quite a bit about CarBEN...
I'm actually having an issue with generating the g-code for one of the sheets -- I thought I found the problem at least a couple of times now, but when I try to load it into the cutting program - it kicks out an error...
Old 10-13-2012, 11:32 AM   #90 (permalink)
I found the g-code problem at long last (about 6 hours of trial and error!) -- there were 6 stray entities so tiny I could not see them... I got rid of them by turning all the cut shapes on the R18 sheet into polylines (an automatic function in DataCAD) and then erasing all other entity types using Mask - whew!! Then re-export the DWG file (for the umpteenth time!) and import that into SU, redo all the outer and inner cuts and all the tabs (again!) and then it the g-code was clean and glitch-free.
Big relief. The PhlatPrinter 3 is now cutting the first copy of sheet R18, thankfully.
Edit: I glued on 4" today and I cut 6 more sheets of foam -- there are only FOUR sheets left to cut and 33" left to glue! Woohooo!
The Following 3 Users Say Thank You to NeilBlanchard For This Useful Post:
aerohead (10-13-2012), Christ (10-23-2012), Flakbadger (10-13-2012)
