Old 10-13-2012, 04:40 PM   #91 (permalink)
shaping
Question for those folks with experience shaping foam -- what works for smoothing small-ish concave surfaces?
Neil,I'm late to the party and you may already have good responses.
I will scrounge convex structures to use as a backing for tailored and glued sanding 'blocks' for concave surfaces and visa versa.
Also,thin masonite or aluminum sheet can be flexed around and attached to a 'shaped' handle,and then 3M self-stick sandpaper attached to the face of the masonite or alum..
Old 10-13-2012, 08:55 PM   #92 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Neil,
I've made foam shapes with the same convex shape, and glued sand paper to maintain that shape.
If you want to flatten the convex shape, then glue sandpaper to a flat board and use that.
Jim.
Old 10-13-2012, 09:40 PM   #93 (permalink)
Thanks -- if I get the large-scale shaping done (assuming that I can finish up the gluing on the warm days), I'll decide if I'll add the more detailed chines on the front fenders with a concave sanding block.
A real bummer at the end of the day today -- I was cutting the 5th from the last sheet of foam (which is good!) -- and the last remaining working USB port on our ~8 year old laptop died. :-(
The computer still runs (several replacement hard drives, and a new power supply) but now I'll have to lug my iMac down and set it up to cut the ~5 remaining sheets. Oh well.
Old 10-13-2012, 11:55 PM   #94 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Gah, so close!
I cannot freaking wait to see this thing. I'll help you sand it, and all you have to do is move yourself and your car to Oregon...
:P
Nissan Leaf driver? Join me in Team Leaf and feel smugly superior about our MPGe
Current Car: White Lightning
Retired Car: Betty White
The Following User Says Thank You to Flakbadger For This Useful Post:
NeilBlanchard (10-14-2012)
Old 10-14-2012, 07:54 AM   #95 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I'll suggest we have a modding party at Neil's place to help him sand and shape the car.
if not this fall we might be able to do something next spring...
The Following 2 Users Say Thank You to Weather Spotter For This Useful Post:
Flakbadger (10-14-2012), NeilBlanchard (10-14-2012)
Old 10-14-2012, 09:04 PM   #96 (permalink)
Two foam sheets left to cut...
And I've sent both the SU and 3DS models of CarBEN EV5 and Dave Cloud's Dolphin to Cd for him to run in Falcon CFD program. We'll see how they work!
Old 10-14-2012, 11:27 PM   #97 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Neil, the model opens fine in the CFD program. I need to get to bed, but ran a quick sloppy test. Here is a short low-res video that is sped up. Will do more testing later.
test2 | Flickr - Photo Sharing!
The Following 2 Users Say Thank You to Cd For This Useful Post:
Christ (10-23-2012), NeilBlanchard (10-15-2012)
Old 10-15-2012, 08:21 AM   #98 (permalink)
Thank you Cd for the quick CFD test (computational fluid dynamics) on CarBEN EV5 last night in a program called Falcon. Even just this brief glimpse is really cool! More to come, I know...
It uses a 3DS file which I was able to export directly from SketchUp. As I read it, the general lack of blue on the back of the model is a good thing?
aerohead (10-19-2012), Christ (10-23-2012)
Old 10-15-2012, 09:03 AM   #99 (permalink)
Keep up the good work Neil, we are all cheering and rooting for you.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 10-15-2012, 06:12 PM   #100 (permalink)
I built my temporary shelter today!
The long scaffolding braces in the foreground are only there to make sure the scaffolding stays up. The ridge and the A-frame legs are H sections made from 16' strapping screwed together, and the eaves are T sections. They are light and relatively strong. The whole shelter was under $100. I need to get stakes to hold the legs of the A-frame down in a wind.
Welcome to my blue world! My 20'x30' tarp is only just big enough...
It would have been a perfect day for gluing today -- it was up in the low 70's, but it was threatening to spit much of the day, so I put up the shelter so I can glue anytime it is above freezing long enough for the glue to dry.
