12-23-2015, 06:33 AM
#141 (permalink)
Are you sure you really can't change all the lights for LEDs?
12-23-2015, 11:08 AM
#142 (permalink)
Originally Posted by oldtamiyaphile
You can use a solid state flasher relay to fix this.
Yes, that is an easy fix. But realy, how mucht time is a blinker on? So how much amps are you saving? I aim not going for an alternator delete, only for lower draws, so the electric heaters can work better.
For the low beams I aim pretty shure that I wont pass the anual car inspection with those being leds...
I tested yesterday how bright the front fog lights are. Those are 27W light bulbs. The low beams are 55W light bulbs. So if i can change the fog lights to high power led lights (so it outputs like a 55W one) then it is ok. The light patern is a bit whider but almost the same distance. If i did the convertion then i would run the parking lights and the fog lights to save amp draw from the alternator.
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011 + 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
01-01-2016, 11:39 AM
#143 (permalink)
YES!!! Happy New Year for everyone.
Just found out that the calculations are in.
This years average target: 5,9L/100km
The fuel log average? => 5,9L/100km
28651 km with 1686.2 L is 5,885L/100km
Fuel savings are: 633L x 1,05€ = 665€
Here is the prologe for so far:
Money saved in 2013 (start to ecomodder): 100€
Money saved in 2014: 460€
Money saved in 2015: 665€
Total money invested: 2095€
Total savings: 1225€
Savings of: -870€
I can drift
01-02-2016, 11:42 PM
#144 (permalink)
Even though you didn't see a quick rebate of the investment, at least your mods have other practical benefits, haven't them?
01-03-2016, 01:17 AM
#145 (permalink)
Absolutely.
I aim always driving with a big smile. Especialy when i look at the fuelgauge, how much km there still are in the tank
The lower highway speed is compensated by leaving 5 minutes earlyer.
All the stress of driving to work is gone.
I aim a lot happier now.
No more stress, like, aaahrrrggg that dude in front of me is driving to slow (5a10km/h under the speedlimit that is 3a6mph)
Hey, and if it goes like this. The payback is a little more then a full year. I can live with that
Even if it takes 2 full years to have a zero. It is still worth it.
I aim planning on driving this car for at least another 4 years. Then it will have around 250000km on the clock. Maybe i will drive it 6 years = until 300000km...
I dont know. It depends on the anual car inspection. If it keeps passing without costing to much monney. Then i will still drive it.
I can drift
01-03-2016, 12:58 PM
#146 (permalink)
I guess a shorter warm-up time might lead to that good feeling. At least the interior gets more comfortable on those cold North Hemisphere winter mornings...
01-03-2016, 01:29 PM
#147 (permalink)
You would think that :P
I almost uso no heater any more.
Wharm up time is massive. When the car used 8l/100km, It warmed up good, and i didnt looked at the temperature of the coolant and use the heater almost always.
Now if the coolant isnt at temperature, no heater for me
I realy need a partial lower grill block soon...
I can drift
01-04-2016, 10:31 AM
#148 (permalink)
Today i got some time to finaly replace the multibelt. It was already a few weeks squeaking.
Searching in the 2288 pages 135Mb garage manual file...
Here is the lay-out of the belt:
The old belt removed and the new belt ready to go in its final position under tension:
Under tension:
And the old belt:
When this was done, i was thinking/dreaming of a partial lower grill block.
I needed some black plastic, or something.
When i was looking for my wrench, i saw an old linceplate laying around.
PERFECT!
So here is what you need:
Saw it in peaces:
Turn the back to the front, and use 4 zipties.
Done
The upper grill block is rated at around 80-85% blocked.
Now the lower is blocked for somewhere around 20-25%.
Hopefully it shortens warm up times, otherwise, there will be blocked even more.
I can drift
The Following User Says Thank You to TimV For This Useful Post:
01-05-2016, 09:23 PM
#149 (permalink)
What about removing that belt-driven fan?
01-06-2016, 06:05 AM
#150 (permalink)
That is actually a good idea. Because even if the viscousius clutch is disengaged. The fan still spins around partially. So there is unnescesary load on the engine.
Is this a good proces for replacement?
- remove the fan of the clutch and remove the fan shroud.
- find and buy an as big as possible electric fan behind the radiator.
- find the signal wire that engage or disengage the fan clutch.
- hack up that wire. Place a relay. And let that signal swith the electric fan on or off.
Optional:
- place 2 smaller electric fans.
- if the signal of the clutch is high. The 2 fans go in series so at low speed.
- place extra coolant temperature sensor and use this signal to switch the fans in parralell or high speed. Place timer. If fans are x time in low speed. Go to high speed.
I can drift
