12-30-2015, 09:22 PM
#61 (permalink)
aero enthusiast
Morelli paper discussion continues here http://ecomodder.com/forum/showthrea...ail-33283.html
This paper will definitely influence my truck aeromods. Oh to be a fly on Morellis wall!
12-30-2015, 10:09 PM
#62 (permalink)
Here's a fluid tail on an old Ford. At least the easy half. The bottom half will be a bit tricky.
12-31-2015, 01:31 AM
#63 (permalink)
aero enthusiast
Freebeard I see this...
The Following User Says Thank You to rumdog For This Useful Post:
01-03-2017, 12:41 PM
#65 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
like it.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
01-03-2017, 02:32 PM
#66 (permalink)
Nice work ...
I noticed the "lift" on my cap as well. ~18"(45cm) @60mph this was on V 1.1 =21lbs (V 1.2 got lift struts, this prevents any possible forgetting as they will openthe cap). I forgot to latch my cap. And noticed light in the center rear view.
? Has anyone else had an self opening experience =negative pressure(lift), or is thos a unique symptom caused by the over hanging duck tail?
Aerohead:
*As to crosswind,it is measured for,dragwise,but I've never seen a report for where it was designed for.
*The body is designed for zero yaw and let the crosswind devil take the hindmost.
* in the spring we can file the report after Darco
*With my compound curves it takes better than 30°of yaw to cause an increase of frontal aera.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 2 Users Say Thank You to gumby79 For This Useful Post:
01-03-2017, 07:30 PM
#67 (permalink)
aero enthusiast
lift
Thanks gumby79, i think aeromods are addictive! Cant stop at one.
I always figured the lift was a result of the shape of cap and airflow together, i hadnt really thought about the tail contributing too much... i would like to extend the other three sides of the tail to match its length. Cover sides with clear plastic over the tail lights and a diffuser/ramp down below
01-04-2017, 12:16 AM
#68 (permalink)
You are in snow country as well. ? Have you noticed a significant reduction in the volume of snow accumulation on the tailgate? Just about every PU hear in Montana has the complete back (top of tailgate/campershell to bottom of bumper) covered with thick snow kicked up in the wake.
Every PU I passed was Wight out even the lights makes them hard to see, there head lights are a better indication of there presents than the covered tail lights.
On December 24 I drove 100mi in hevy snow @60-45mph and this is all the snow I accumulated, see pic. attached.
Notice the gap between the bed and bumper. This indicates to me air flow through the gap. And also the ball holes in the step. Have been kept open from air flow.
Former
87' Hyundai Excel
01-04-2017, 02:04 AM
#69 (permalink)
aero enthusiast
snow
I do find the cold weather interesting from an aero point of view, like you say with the snow build up and road grime on the rear, and also when it gets real cold like below minus 30 celcius (like zero f) the exhaust gasses last much longer, almost like a smoke trail in a windtunnel. One can finally see what the air is doing! It would be fun to research this stuff full time.
