03-11-2013, 02:51 PM
#51 (permalink)
I do like that 2nd one.
One fly in the aesthetic ointment I forgot to mention: the front licence plate has to go back on, and it'll be mounted just right of the car's centerline on the lower block
03-11-2013, 03:39 PM
#52 (permalink)
i still dont think it would look that bad
you could make a mounting ring to overlap and secure the plate?! would be a clean flush install if you wanted to spend a couple more hours on the overall porduct
EDIT: does your jurisdiction/city allow the Tinted plate covers?! It may help, not stick out like a pimple
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
03-11-2013, 04:14 PM
#53 (permalink)
After seeing ROB's renditions, an afterthought would be to have the lower grille block centered with a small inlet on each side, then the plate could go on in the middle?
Unless the Insight is like other Hondas with the small rad offset to one side, then my idea is poo...
2016 BMW 535d
4100lb XDrive Eco-Yacht
03-11-2013, 06:05 PM
#54 (permalink)
Or two grill blocks with the hole centered.
I like the look of the grill blocks, I vote for either color matched or black. And, yes, I realize my vote doesn't count .
03-12-2013, 10:04 AM
#55 (permalink)
For simplicity, i love the look of the offset opening, it gives it a almost factory "theres something amazing about this car that you never knew" type presence... asymetrical is overated
03-12-2013, 10:11 AM
#56 (permalink)
I like it offset for that reason, too.
But the engine radiator is offset on that side, so it's functional too. I could have centered the small opening on the left side, but then I would have had to make a shaped plug to stick on the extreme left to guide the air into the reduced opening.
03-12-2013, 12:14 PM
#57 (permalink)
not to mention, once you boattail it, everything qwerky will look right at home and proper overall.
07-14-2013, 09:52 AM
#58 (permalink)
day-glo it is
Fluorescent green FTW!
(Not photoshopped.)
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
07-14-2013, 10:44 AM
#59 (permalink)
Always Too Busy
Wow that is obnoxious and gorgeous all at the same time.
Nissan Leaf driver? Join me in Team Leaf and feel smugly superior about our MPGe
Current Car: White Lightning
Retired Car: Betty White
08-05-2013, 08:26 PM
#60 (permalink)
Could you elaborate on what materials you used for the surface finish? Paint (spray paint?), putty, sanding, epoxy? Just to make the process idiot proof for someone like me. I also need to make a side mirror plug using the same technique.
Bondo?
I try to be helpful. I'm not an expert.
