Old 01-19-2012, 11:16 AM   #11 (permalink)
Project EconoPolo - '04 Volkswagen Polo Twist TDi
90 day: 48.23 mpg (US)
So yesterday I went through a few stages of grille blocks.
First off I made a top grille block by gluing glossed rubber to the back:
However after seeing some other blocks, I did a little bit of CFD and discovered that the blocked version still created turbulence and drag. So I decided to go for a full on cut to size and smoothed in version.
By the way this material is actually armoured mudflap rubber which I bought for my Subaru and didn't fit
I knew I'd be ecomodding this car, and now I'm REALLY glad I decided to get it in black!
Viio
Amateur SolidWorks Flow Simulator
Link to my Project EconoPolo (aeromodding a VW)
Old 01-19-2012, 11:35 AM   #12 (permalink)
Here's a shot of the CFD from the first blocked (but not smoothed) grille.
All the twisty turbulent red velocity lines are bad, even if it's only on a small area I'd rather not have my grille creating drag.
Viio
The Following User Says Thank You to viio For This Useful Post:
Vekke (01-21-2012)
Old 01-19-2012, 12:21 PM   #13 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
That really looks nice with the smooth lines of the Polo. I take it the Polo doesn't have the engine air intake at the top slat of the grill like my Golf does? (I left one side of the top grill bar open for that reason.)
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 01-19-2012, 12:34 PM   #14 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
Originally Posted by Vekke View Post
Oh and remember to take out the rear muffler. It should help a lot.
I did this on the diesel Golf and replaced it with a straight pipe. I don't have any test data to show if it helped horsepower or mpg but it didn't hurt any. The noise level in the cabin is virtually unchanged. With the turbo and the cat dampening the exhaust pulses it is not loud.
TDi=fast frugal fun
Old 01-19-2012, 12:34 PM   #15 (permalink)
It does, but I've removed the cold air feed so the airbox takes air straight from the engine bay. It'll help the car warm up faster on short journeys and I'm not bothered about slight power drop. Intake temp monitor reads about 15c, so about 10 degrees above ambient.
Viio
Old 01-19-2012, 12:57 PM   #16 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
Upper block looks very nice! Great job!
Old 01-20-2012, 02:42 PM   #17 (permalink)
Cd
Ultimate Fail
Cd's Avatar
The flush grille block looks completely stock ( and in my opinion, even better than stock.)
Old 01-20-2012, 02:47 PM   #18 (permalink)
Thank-you for that. That's what I was hoping for! I took some inspiration from the Bluemotion and decided to just block the whole thing in gloss black.
Viio
Old 01-21-2012, 06:33 AM   #19 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
This may be the best looking grill block I've seen.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
The Following User Says Thank You to JasonG For This Useful Post:
viio (02-25-2012)
Old 01-21-2012, 12:36 PM   #20 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Block sure looks cool. If you want to make it perfect you need to take about 10mm out from the cars left side piece to make them symmetrical .
Yes when you take out the rear muffler you wont even notice it while driving.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
