Old 03-25-2012, 10:38 AM   #51 (permalink)
Project EconoPolo - '04 Volkswagen Polo Twist TDi
90 day: 48.23 mpg (US)
Today I've been busy - I've been making rear wheel skirts/fairings.
First of all I made a cardboard template.
Then used some more of my acrylic plastic sheeting, cut out using the template with lots of spare around the edge.
Then I used a heatgun what I purchased this morning to bend around some edges and flare it out a bit for fitting round the tyres.
Here it is moulded and in position.
Then I got to cutting out one for the other side.
And some wider shots so you can see what's what.
Now the paint is drying and I'll fit the brackets in a couple of hours
Viio
Amateur SolidWorks Flow Simulator
Link to my Project EconoPolo (aeromodding a VW)
The Following User Says Thank You to viio For This Useful Post:
aerohead (03-27-2012)
Old 03-25-2012, 11:05 AM   #52 (permalink)
Could I ask where you got the gloss-finish black rubber? It certainly looks the business...
I'm also worried about making my car look too 'ghetto' as I think you called it!
Old 03-25-2012, 11:37 AM   #53 (permalink)
On ebay, it's actually 4mm rally mud flap material. From JJC: JJC Rally Mud Flap Material 4mm MSA Spec Pair Blk | eBay
I got it for my Subaru but used it on the Polo instead :P
Viio
Old 03-25-2012, 11:40 AM   #54 (permalink)
Here's one side fitted - much cleaner than the rest of the car lol
Viio
The Following 2 Users Say Thank You to viio For This Useful Post:
aerohead (03-27-2012), Vekke (03-27-2012)
Old 03-25-2012, 01:09 PM   #55 (permalink)
My other job completed today, two inserts for wind deflecting the wiper blades:
Viio
Old 03-26-2012, 07:37 PM   #56 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Errr, the front mud flaps are still on !
(They're a drag )
Old 03-27-2012, 02:59 AM   #57 (permalink)
Noted, I'll sort those at the weekend
Viio
Old 03-27-2012, 05:16 PM   #58 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
http://wwwm.coventry.ac.uk/researchn...%20Vehicle.pdf
Thats pretty similar car so effects are almost the same in your car. This means you can compare your Cd calculation results to those .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 4 Users Say Thank You to Vekke For This Useful Post:
aerohead (03-27-2012), COcyclist (03-27-2012), Grant-53 (03-29-2012), viio (03-28-2012)
Old 03-28-2012, 03:50 AM   #59 (permalink)
Nice find that was good reading!
Viio
Old 03-29-2012, 12:49 PM   #60 (permalink)
Nice work so far and the coventry.ac.uk pdf gives a good idea what areas give the biggest gains.
