Today I've been busy - I've been making rear wheel skirts/fairings.
First of all I made a cardboard template.
Then used some more of my acrylic plastic sheeting, cut out using the template with lots of spare around the edge.
Then I used a heatgun what I purchased this morning to bend around some edges and flare it out a bit for fitting round the tyres.
Here it is moulded and in position.
Then I got to cutting out one for the other side.
And some wider shots so you can see what's what.
Now the paint is drying and I'll fit the brackets in a couple of hours
![](http://i4.photobucket.com/albums/y146/viio/ecomodder/th_20120325_140947.jpg)
