Old 08-31-2018, 08:11 PM   #21 (permalink)
I will check into on Tuesday. Camping right now for the weekend. I will check my phone from time to time. There also maybe an issue with the rocket-tabs.com email. My support person is working on it.
Old 08-31-2018, 10:00 PM   #22 (permalink)
No one else is doing saying it but I will.
I'm calling BS on 20%.
Maybe 5% or less I could believe.
And if they worked we would already be seeing them on tractor trailers, but tractor trailers have opted for smooth hub caps.
I could test a set and I have the perfect vehicle to test something like this with. I have a nissan leaf that gives real time traction power output. Anything that reduces drive power consumption by anywhere near 10% would be an very, very obvious above 60mph.
Xist (12-09-2018)
Old 09-01-2018, 04:30 AM   #23 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
I wouldn´t be so harsh. There is slight chance you really have discovered something new.
But I think everyone here agrees you need to do a proper A-B-A testing before you make such claims here. See this thread:
https://ecomodder.com/forum/showthre...tml#post147532
... and come back with results.
Old 09-01-2018, 05:31 AM   #24 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
3 small triangles per tyre, resulting in 5 to 20% improvement in FE ?
Ain't happening.
Let's move this to the Corral ...
The Following 5 Users Say Thank You to euromodder For This Useful Post:
broski499 (11-15-2018), Ecky (09-04-2018), elhigh (09-03-2018), samwichse (09-01-2018), Xist (12-09-2018)
Old 09-01-2018, 05:46 AM   #25 (permalink)
euromodder's Avatar
Originally Posted by Kacz42 View Post
My mistake. I have had no damage to the tires other than the small amount of glue left behind. The 25 dollar price is installed. $5.99 for a set with extras. Again sorry for the error.
Your website doesn't offer an option without installing
25$ / set is the only option
I'll take 2 sets @ 6$ + shipping (if it's reasonable to the EU) and give them a go
Old 09-01-2018, 10:32 AM   #26 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Part of the reason I wanna test this is that the vortex generated around the tire could eliminate the need for wheel skirting, maybe could help mileage on cars lacking full skirts... I do agree with oil pan though, 20% most likely ain’t gonna happen...
My current Ecotec project...
My last Ecotec project...
Old 09-01-2018, 03:16 PM   #27 (permalink)
Permanent Lurker
seifrob's Avatar
A funny side note regarding efficiency:
Let us say you have a mod worth of 1 mpg ( your car travels 1 mile further per gallon).
When you apply it on an average ecomodder members Insight, not a big deal going from 57 to 58 MPG. 1.7 percent.
But, if you apply the same mod on a car someone is driving with 18 MPG, you can celebrate five, almost six percent increase!
Percents are misleading.
The Following User Says Thank You to seifrob For This Useful Post:
oil pan 4 (09-01-2018)
Old 09-01-2018, 03:47 PM   #28 (permalink)
Team Saturn
5% is 1mpg at a 20mpg average, but it’s 2.5mpg at an average of 50...
Old 09-01-2018, 09:05 PM   #29 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Tires already shed 3 pairs of vortices, which is why a spinning tire generates less drag than a non-spinning one. It isn't clear to me that 1) placing these tabs on the tire, so they're spinning with it, will generate vortices (how are they shaped?), or 2) if they are, that the vortices generated will somehow have a beneficial interaction with the existing vortices around the tire and lower its drag.
I agree, this should be moved to the Corral until the OP provides some documentation to back up his claims, especially if he came on here to sell these.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
chumly (09-02-2018), oldtamiyaphile (09-02-2018)
Old 09-02-2018, 09:53 AM   #30 (permalink)
92 Civic VX since 2002
Magician's Avatar
Green Bean - '92 Honda Civic VX
90 day: 58.68 mpg (US)
Wife's Prius - '08 Toyota Prius Base 315K miles
Silverbullet - '08 Toyota Prius
Just think... a boat tail is probably the mod with the largest gain... and some add on to tires is supposed to as significant? Prove it.
more mpg
