02-13-2010, 02:02 AM
#71 (permalink)
Originally Posted by oldbeaver
Back to Jedi_sol comment: what is AERO? Please explain. Tks.
Sorry, AERO-dynamic mods (underbelly tray, wheel skirts, kammbacks, etc.), stuff that's been proven to work.
02-13-2010, 12:40 PM
#72 (permalink)
57.4 mpg best trip.
I see. Tks.
02-17-2010, 06:55 AM
#74 (permalink)
EcoModding Alien Observer
Read the testimonials...then MOAN....?
Testimonials Supplemental Hydrogen Use
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
02-17-2010, 10:18 AM
#75 (permalink)
Moderate your Moderation.
Simple answer - They're testimonials.
In essence, worthless.
02-17-2010, 07:53 PM
#76 (permalink)
57.4 mpg best trip.
0.6 improvement with HHO measured with Mpguino?
Accordingly to Stonebreaker, even a 0.6% improvement on engine yield is not possible.
On the other hand, if it is possible, then it may be a matter of efficiency of the electrolysis machine used. This machine yielded 0.6% improvement, but maybe other may yield more improvement?
And what about the Turkish paper cited by Tangomar? It claims a very serious improvement on 4 cars using onboard HHO generation. The only difference of the method is precisely the electrolysis machine used: they used electrodes made of Carbon and Platinum instead of stainless steel.
However, the paper do not say clearly how they measure fuel consumption. If it is a diesel engine, it si not an easy task.
Oldbeaver
02-17-2010, 08:00 PM
#77 (permalink)
57.4 mpg best trip.
How did you connected Mpguino to the diesel engine?
Jedi Sol,
From the best of my knowledge, MPGuino is not suitable to be connected to a diesel engine. How did you do that? For me this is the only valid method to check fuel yield improvements, not only of HHO, but for aerodynamics, mechanics, driving habits and so on.
I want to learn as I have one in my hands and want to connect it also.
Thank you,
OldBeaver
Originally Posted by jedi_sol
I've been testing my HHO for about a year now without definitive results, until just recently I installed an MPG guino.
Did some A-B-A testing and the MPGuino results were = 0.6% increase in mpg.
To me, that's hardly any proof that HHO works and I'm going to give up on this project and focus on AERO!
02-17-2010, 08:34 PM
#78 (permalink)
If you want to experiment with carbon electrodes, you can get some from old, used, alkaline batteries. The middle of the battery (in most cases) is a carbon electrode that works nicely for carbon lamps.
02-21-2010, 11:03 AM
#79 (permalink)
57.4 mpg best trip.
Energy necessary to electrolize 1 mol of water
Dear Stonebreaker,
You wrote: "The energy required to electrolyze one mole of water is 237 kilojoules. So 11.78 moles requires 2791 kilojoules of energy - call it 2800 kilojoules. That's 2800 kJ per minute. To figure out the wattage, divide by 60 to get 46.7 kJ per second, which works out to 46,700 watts. Which, at 14.4 volts, is 3200 amps."
If the base of the calculations is correct, you are right. I know you took the figures of energy required to electrolyze one mole of water as 237 kilojoules from a physics page, however, I still have a question that may reverse your conclusions:
That figure (237 kilojoules) may be essential to a particular electrolysis device, not a standard. From my personal practical experience, performing electrolysis with two different devices yields different results.
If I am right, anyone will get completely different performances depending on how efficient is the device you use. Then the 237 kilojoules figure on which is based our previous reasoning may be just a particular case, read "wrong".
Can you tell me why you took the 237 kilojoules of that page of physics as a standard?
For example, for my 2.8 liters engine, my first electrolizer device used 25 to 30 Amps producing little HHO gas, while the second used 15 to 20 Amps producing a lot of HHO gas. The second is about 5 times more efficient than the first. Anyway, both are very far from 3200 Amps.
For this, I suspect 237 kilojoules is not an efficient performance for electrolysis: I cannot imagine a wire able to cope with 3200 Amps!
Old Beaver
Originally Posted by stonebreaker
I've got an idea. Get rid of the diesel altogether. If burning hydrogen with oxygen to get water returns more energy than it costs to separate the water into hydrogen and oxygen, then there's no reason to involve diesel at all. Just set up a big ol' HHO generator and fill the gas tank with water.
Even assuming a 5% concentration of H2 did everything claimed for mileage and emissions:
A duromax diesel displaces 6.6 liters. Even neglecting the turbo charger's boost, that's 5.28 cubic meters of air per minute at 1600 rpm. At a 5% mix as suggested in the above emissions test, that's .264 cubic meters, or 264 liters, of hydrogen per minute used in the test as a "catalyst". A mole of hydrogen is 22.4 liters at STP. So we're talking about 11.78 moles of H2 per minute.
The alternator on the duramax trucks is 145 amps. Even dumping 100% of the alternator's output into the HHO generator, you could only produce less than 1/20th of the required 5% H2. Plus you'd run your battery down in 15 or 20 miles.
Incidentally, 46,700 watts is equivalent to 63 horsepower. Never mind whether your alternator could make that wattage, your fan belt couldn't deliver the power in the first place!
So it doesn't matter if HHO works or not. Your car doesn't have the ability to make enough hydrogen anyway.
Incidentally, hydrogen isn't made commercially by electrolyzing water. (It's too expensive.) Commercial operations create H2 by injecting superheated steam into natural gas. The reaction is CH4 + 2(H2O) -> CO2 + 4(H2). the H2 is compressed and bottled and the CO2 is sequestered underground.
Really, really useful unit converter:
Unit Converter - Digital Dutch Unit Converter
Reason: improving
02-21-2010, 02:02 PM
#80 (permalink)
naturalextraction
How many liters of hydrogen per minute are you producing with your second unit? And will it's production meet at a minimum of 5% of the total volume of diesel fuel/air ratio per minute that your engine requires to operate normally? That is usually the problem. Then metering the amount in a means per cylinder. Injection timing is crucial with diesel. If you made 5% to 7% per the necessary volume then lessening the amount of diesel injected per that volume would be needed to achieve the gain.
Again this guy spells/mathematically it out for you in regard to volume @ rate, etc. Hadn't forgot about some references for you, I've been on jobs for a while.
http://www.youtube.com/user/Silverad.../0/oP6woNV4IvU
