Old 10-28-2015, 05:25 PM   #11 (permalink)
Kamm efforts
Originally Posted by skyking View Post
thanks Phil. This all gives me hope that my Kamm efforts are the way to go.
From Jaray's,Lay's,Kamm/Fachsenfeld's,Hucho's,and Buchheim et al's research,it's the only thing which has a track history of performance.
Darin's Honda proved that it's not a 100% solution though.I suspect that there was drag reduction,but the engine didn't react favorably to the mods.
Chrysler and Dr. Gino Sovran warned about gear-matching requirements.Hope you don't hit a snag.
Old 10-28-2015, 07:44 PM   #12 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
But ...but ...it has a pointed nose.
More of that "entemodynamics" I have spoken of in the past. If the bugs don't stick it must be a good thing
I agree. I still think a flat spoiler would look cooler, or at least strange in a striking way, but I bet you get better results with your Kamm ideas.
I am kicking around a kamm with a big wing..... or two. fun fun!
My TDI's fuel specifics are so much better than a gasser, and I will be adding a 6th gear eventually. I don't imagine that being an issue, ever, at any speed.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 2 Users Say Thank You to skyking For This Useful Post:
aerohead (10-31-2015), UFO (11-02-2015)
Old 11-01-2015, 11:41 PM   #13 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I believe our diesels are less sensitive to throttle position changes due to the diesel engine's lack of a throttle plate. Improved aero should only help efficiency since they simply add less fuel with reduced load and can run very lean compared to a gasser. That said, if you can do the 6 speed swap and keep the engine at about 1,800 rpm at your chosen highway speed that is the sweet spot for BSFC for the TDI. It's on my wish list.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 11-02-2015, 12:20 AM   #14 (permalink)
Back when I had the 1961 VW panel van, I thought about two Porsche duck tails, vertical on the sides, to create what I would verbalize today as a virtual plan taper.
More for directional stability than downforce, like a shuttlecock.
Old 11-02-2015, 09:37 AM   #15 (permalink)
I had a similar thought last year or two ago when those air-tabs on the side of vans first came out. Although it would be just the common Wickerbill sized Gurney flap all the around the rear edge.
Old 11-02-2015, 09:33 PM   #16 (permalink)
Once I'd hung around here for a while, I leaned more toward a rectangular 4" torus fed with the pumped engine cooling air, with louvers punched lengthways at the proper angle to form a Coanda nozzle on all four sides.
Today though, things are different. The news out of Manchester University:
The future of flight: plasma aircraft wings | News & Events | Manchester Metropolitan University
MMU Homepage»News & Events» The future of flight: plasma aircraft wings
Electrically charged field replaces mechanical flap
A prototype plasma wing with the distinctive purple electrical field
ELECTRICALLY charged plasma fields are being used to improve aircraft performance by generating lift in place of mechanical wing flaps and slats.
Tests show that plasma could be adopted to replace the actuator flaps on aeroplanes that help them to climb, descend and alter speed.
aerohead (11-03-2015), skyking (11-03-2015)
Old 11-03-2015, 11:25 AM   #17 (permalink)
POSTED BACK IN 2011................four years ago.
Page 2
Why are many UFOs an aerodynamic, saucer shape?
Why are many UFOs an aerodynamic, saucer shape?, page 2
A DARPA sketch showing plasma edges....................
The plasma charge on the leading edge of the wing reduces the drag
How long before our cars start glowing blue?
The Following 3 Users Say Thank You to kach22i For This Useful Post:
aerohead (11-03-2015), Cd (11-03-2015), skyking (11-03-2015)
Old 11-03-2015, 11:48 AM   #18 (permalink)
skyking's Avatar
Puddle lights? we don' need no stinking puddle lights!
2003 TDI Beetle
2002 TDI Beetle
Old 11-03-2015, 03:17 PM   #19 (permalink)
Purple? They've been preparing us since Tron, with the blue strip lights on everything.
Old 11-03-2015, 03:27 PM   #20 (permalink)
90 day: 54.08 mpg (US)
I need plasma wings on my belly pan!
And spinner moon discs.
