Old 03-27-2009, 10:07 AM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
diy "cruise" control (cable actuated throttle lock)
Ok, maybe more of a throttle control, but anyway, it's easy cheesey This location is easy for the right hand, and a push with the palm shuts it down. Can always use the thumb kill switch to shut down engine or clutch to disengage (and it's only a 3cyl metro here) so not too worried about runaway.
It could be lined up left-right a little better on the chain side (needs a zip tie), but it works pretty good as is, and I only had to remove the center console to install it.
Old 03-27-2009, 10:51 AM   #2 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 43.34 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 106.98 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
Looks like a great setup, could you give us more detail on what/where your got the control?
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 03-27-2009, 11:18 AM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
It is a vernier control, like might be in a utility vehicle or a gen-av airplane. I forget where I got it, think I shopped around and found it for like $35.
similiar units:
Horton Truck - Parts Detail
eBay Motors: LOCKABLE VERNIER THROTTLE CABLE ASSEMBLY (item 130132963664 end time Mar-30-09 11:36:45 PDT)
The twist fine tune function is nice, hopefully I can dial in best mpg on the flats with it.
Old 03-27-2009, 11:56 AM   #4 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
That looks nice. Constant small adjustments for DWL over long distances can be a pain (literally) to the foot/calf.
(Of course jomelmaldonado's load-sensitive cruise control hack would solve that...)
Looking forward to a report once you've had some time to use it.
Old 03-27-2009, 02:20 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
dcb -
I like it. Maybe this isn't logical, but I like adding knobs and controls to the inside of the car (especially if they do something!). Your implementation is butch. When I talk to people, I sometimes compare how I drive to flying a plane, because I am always monitor more dials and doohickeys than otherwise (but that's the fun part!).
Also waiting for the status report.
CarloSW2
American Solar Energy Society
Old 03-29-2009, 09:55 PM   #6 (permalink)
high school
ModelE's Avatar
sabre - '02 LeSabre Custom
90 day: 23.45 mpg (US)
frontier - '04 Frontier XE
90 day: 18.97 mpg (US)
will that pass inspection
Old 03-29-2009, 10:22 PM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
Yes, but I don't live in boston I'm sure there's plenty here that wouldn't pass a boston, or baltimore, type inspection (non-oem air freshener?).
re: report, well the mrs took it up to traverse city, said it was nice to have on the hiway. It isn't super sensitive with this setup. It helps if you hold the throttle with your foot and pull the knob out till it hits the stiff resistance. For fine tuning you have to help the pedal with your foot (really light taps or lifts) while turning the knob.
Not exactly sure how to test it, what to compare it to and where?
Old 03-29-2009, 10:32 PM   #8 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
Does the chain pull the gas pedal down? I couldn't quite see on the picture.
Nissan Versa Aeromods
Old 03-30-2009, 10:10 AM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
The chain pulls on the gas pedal lever near where the lever pulls on the cable that goes to the throttle body. This moves the pedal towards the floor via the pivot (the rust colored bracket on the lower left of the last pic).
Old 03-30-2009, 12:54 PM   #10 (permalink)
That VX guy!
TomO's Avatar
Could lubricating the pedal pivot point with silicone lube assist you in your minor adjustments?
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 01:59 PM
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 03:36 PM
Throttle locking the cruise control? Xringer EcoModding Central 6 12-26-2008 11:29 AM
Reprogramming cruise control. TKWPrime EcoModding Central 7 09-22-2008 05:49 PM
Cruise control mod idea rjacob DIY / How-to 18 07-30-2008 12:27 AM
