04-02-2008, 11:37 AM
FuelSipper
DIY: tire bands for Air Pressure Sensors
vo7888 at my350z.com has a write up on creating tire bands for Air Pressure Sensors. This is a great DIY for those wanting to see their air pressure on their tires on the fly.
http://www.my350z.com/forum/showthre...ht=tpms+bandin
04-02-2008, 09:44 PM
Interesting.
You know, I bet once you have air pressure monitors on a vehicle, it's the type of thing that makes you wonder "what did I do without these before..."
04-25-2008, 10:38 AM
has anybody done this ???
04-25-2008, 10:44 AM
I don't think so - just the person at the other forum, linked above.
04-25-2008, 11:04 AM
Originally Posted by dremd
ya I'm a bit to tight to spend that when i can do it ,,,,,,I do need a better tire gauge
05-07-2008, 01:44 PM
Modified Driver
Location: South Western middle of nowhereish New Hampshire
There is a cheaper alternative... I've seen valve stem caps at Wal-Mart that will change color if your tire is running low. Sure, you actually have to get outside your car and visually check them, and they won't tell you if your tires are over-inflated, but even though I don't remember the specific price, I'm sure they are a lot cheaper than a TPMS.
05-07-2008, 01:49 PM
Modified Driver
Tire Minder
Here we go. I found the Tire Minder system for under $20.  There may be cheaper versions available. I'm not sure.
http://garage-toys.com/tireminder.html
05-07-2008, 02:30 PM
#9 (permalink)
I had a set of those once. The 32 psi version. They wouldn't show yellow until about 26-27 psi, and red was down at about 20. Maybe if you got some in 50 psi and tried to keep it in the yellow zone for 44. Then again, I doubt they'd accept the liability of making these for pressure above the tire's sidewall.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
05-07-2008, 07:03 PM
#10 (permalink)
Giant Moving Eco-Wall
*mimics man*
Hmm. I don't quite recall.. but I think I used one of them ancient tire thingy's. Reminded me of a rod, sometimes I'd see a gauge looking thing, but... wait are those things still around???
Yea, except they don't recede until they reach about 20psi. then they say your tires are low  My mom used to have some. You can tell when your tires low by that point! When you look at the front of the tire and see that it's squishy you know that you need to put air in it!
