Old 04-02-2008, 11:37 AM   #1 (permalink)
FuelSipper
HondaHokie - '95 Honda Accord DX 4 door
90 day: 26.91 mpg (US)
DIY: tire bands for Air Pressure Sensors
vo7888 at my350z.com has a write up on creating tire bands for Air Pressure Sensors. This is a great DIY for those wanting to see their air pressure on their tires on the fly.
http://www.my350z.com/forum/showthre...ht=tpms+bandin
Old 04-02-2008, 09:44 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Interesting.
You know, I bet once you have air pressure monitors on a vehicle, it's the type of thing that makes you wonder "what did I do without these before..."
Old 04-25-2008, 10:38 AM   #3 (permalink)
Blue - '77 Chevy P/U
has anybody done this ???
Old 04-25-2008, 10:44 AM   #4 (permalink)
I don't think so - just the person at the other forum, linked above.
Old 04-25-2008, 10:45 AM   #5 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
The TPMS on nissan is similar to BMW/ Mercedes (the only ones I've worked on)? I'm not a member on 350z forum.
Or for a vehicle not previously equipped with TPMS
$176 Not BAD, but I'm not buying ne anytime soon.
http://www.tirerack.com/accessories/...4x035&code=yes
http://www.amazon.com/Hella-Pressure.../dp/B000QSDZQC also
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 04-25-2008, 11:04 AM   #6 (permalink)
ya I'm a bit to tight to spend that when i can do it ,,,,,,I do need a better tire gauge
Old 05-07-2008, 01:44 PM   #7 (permalink)
Modified Driver
Twerp's Avatar
Location: South Western middle of nowhereish New Hampshire
Frozen Tundra - '03 Toyota Tundra 4WD SR5 Access Cab
90 day: 26.51 mpg (US)
Red Skateboard - '91 Honda Civic DX
90 day: 45.49 mpg (US)
There is a cheaper alternative... I've seen valve stem caps at Wal-Mart that will change color if your tire is running low. Sure, you actually have to get outside your car and visually check them, and they won't tell you if your tires are over-inflated, but even though I don't remember the specific price, I'm sure they are a lot cheaper than a TPMS.
Old 05-07-2008, 01:49 PM   #8 (permalink)
Modified Driver
Twerp's Avatar
Tire Minder
Here we go. I found the Tire Minder system for under $20. There may be cheaper versions available. I'm not sure.
http://garage-toys.com/tireminder.html
Old 05-07-2008, 02:30 PM   #9 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I had a set of those once. The 32 psi version. They wouldn't show yellow until about 26-27 psi, and red was down at about 20. Maybe if you got some in 50 psi and tried to keep it in the yellow zone for 44. Then again, I doubt they'd accept the liability of making these for pressure above the tire's sidewall.
Old 05-07-2008, 07:03 PM   #10 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
*mimics man*
Hmm. I don't quite recall.. but I think I used one of them ancient tire thingy's. Reminded me of a rod, sometimes I'd see a gauge looking thing, but... wait are those things still around???
Yea, except they don't recede until they reach about 20psi. then they say your tires are low My mom used to have some. You can tell when your tires low by that point! When you look at the front of the tire and see that it's squishy you know that you need to put air in it!
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
