...the "stock" OEM camshaft that came in the engine is about as "tame" and MPG-friendly as you're gonna get.
...although, you CAN can a standard camshaft custom "reground" for more low-end performance at expense of higher-rpm power...ie: better mpg, but lower hp.
...contact a local camshaft shop...if *they* can't do it, they'll probably be able to recommend someone nationally who can do it (but not totally cheap).
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
