06-11-2017, 10:43 PM
#61 (permalink)
Cyborg ECU
Rebuild and weight reduction
The new look of "black and red" ...
I still have some wire tucking to do (thinking this stuff) and a couple other small things, but here it is:
The rebuild took 6 pounds off, gave me a lower center of gravity, and greatly improved handling by bringing weight forward of the rear axle. I also solved an intermittent brown-out problem (turned out to be a loose wire in a connector). I made the bracket for the battery out of the battery box portion that I cut in order to fit the frame triangle. First time I ever have made any sort of mount or bracket. It is very solid. It's not very pretty.
Fully loaded with bike lock, toolkits, parts, battery mount--as in the old photo below--the bike was 51 lbs. Now it weighs 45 lbs.
I hope that moving the weight off the back tire will also reduce the frequency of punctures.
The new bike lock is that rectangle above the top tube. It is a titanium TiGr Mini+, and it coast $135. I love it. It weighs 1 lb. My old lock weighted in at about 2.5 pounds.
The Following 4 Users Say Thank You to California98Civic For This Useful Post:
06-11-2017, 11:23 PM
#62 (permalink)
As much as I like pretty it's safety first. I mounted my handlebar bag on top of the bar and parallel to the ground. The light can mount underneath since I made my own aero bars.
06-12-2017, 02:46 PM
#63 (permalink)
Cyborg ECU
Have you posted pics of your setup? I'd love to see.
06-14-2017, 08:53 PM
#64 (permalink)
I have three things going at once this week but I will make a concerted effort to do pictures soon. High school graduation, garden planting, and grandkids coming. The bag is by Sunlight and snaps to a plastic frame.
06-15-2017, 10:31 PM
#65 (permalink)
Cyborg ECU
So, I figure with the new costs for the remod of this ebike, my total cost is about $1675 now. At $0.55/mile cost for driving (my employer's rate) it would be 3045 miles before I "break even" on costs by riding instead of driving. At the $0.06 rate suggested by my average fuel costs for my EM car, it would be approx 28,000 miles.
Lotta two-wheelin' !!
08-09-2017, 09:48 PM
#66 (permalink)
マット
What voltage and Ah is your battery pack?
Thanks, Matt
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
11-26-2017, 07:41 PM
#67 (permalink)
Cyborg ECU
Thanks, Matt
Somehow I missed this question man. Am very sorry. My battery pack is a 14 amp hour Lithium set up for 36 volt system.
02-08-2018, 07:46 PM
#68 (permalink)
Cyborg ECU
My ebike battery charger is dead (I tested with a multimeter). Any advice on replacing it? My set up is 36v. I have a 14 ahr lithium battery. The old charger is rated on the case as 43.2 volts and 2.5 amps. It took hours to charge from half depleted. I'd spend a little for faster charging, like maybe a 7 amp charger. Thanks as always for all your useful advice, people.
02-09-2018, 12:00 AM
#69 (permalink)
I'm cheap...I'd go source one out on ebay. Just make sure it's designed/rated for the right number of cells and chemistry(though your BMS will probably prevent over-charging...you still need enough voltage). You can always change the plug on it to match your battery's charge port.
There's probably a 5a one out there. I bought a 5a 72v one a while back.
Quick search example:
https://www.ebay.com/itm/371918053640
The Following User Says Thank You to Stubby79 For This Useful Post:
02-09-2018, 12:45 PM
#70 (permalink)
Cyborg ECU
Wow, that is cheap! And it is virtually my exact charger, but higher amperage. And mine has the plug with a male stem inside a round barrel. It only has +/- and no ground (I think), unlike this three prong which is grounded. What would I do with the ground wire? Maybe an adapter? Cut it and wrap it? I suppose I could dismantle the battery box and replace the female plug instead. Hmmmm.... I wish there was still a plug and play but I have been looking and suddenly they all seem to be three prong.
