Old 10-12-2008, 01:45 AM   #1 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
God, I love my MpGuino!!
I was trying to figure out why my Guino keeps resetting tonight and decided I would practice P&G a little more. The coolest part about the guino is the big current display, can instantly tell if your mileage is going up or down. No more waiting to fill up and see.
I shocked myself tonight with this one.
89.2 over a distance of 9.37miles all in town!!
I am totally freaking out at this point, the MpGuino and P&G rock.
Old 10-12-2008, 05:59 AM   #2 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 scenic
90 day: 43.09 mpg (US)
megane - '97 megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Prius
90 day: 55.5 mpg (US)
Congrats
You'll skyrocket your MPG
Could you post a picture of your MpGuino connections under the hood please ?
TIA,
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 10-12-2008, 11:15 AM   #3 (permalink)
Addicted
bbjsw10's Avatar
All my connections were made at the ecu under dash, except power ground which are to ignition switch battery feed wire, and ground is to chassis.
Yeah will definitely take up mileage, the best I pulled before in town, without guino was 57mpg.
Old 10-12-2008, 12:25 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Nice job! That's a very impressive trip right there
Old 10-13-2008, 01:19 PM   #5 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Good job, hope you get the rest of it figured out. Hope the new resistors make a difference, but Im really not sure what to use, Id have probably tried the same as you did.
I feel like I cant live without mine either. I prefer the first display, so I can keep an eye on both the instant mpg, and use that to keep the current mpg up. Occassionally Ill toggle to the tank mpg just to see, then toggle back. I also usually use the first display as my speedometer, since it is very stable and more accurate than the factory needle. Im still running version .70 since it works 100% flawlessly for me.
Got my best trip and tank last night. 38.6 tank average, and my trip back from downstate last night to the local gas station was at least 39.84 mpg over 142 miles. Guino read 5% high on fuel use, so it was probably more like 41.8 mpg.
Im getting variations of about right on to about 8% high, most likely based on fillup differences. +/- 4% is pretty good. I should probably reset my microseconds/gallon to about 4 or 5% higher which seems like the average, but I kinda like knowing that Im getting at least what it says I am, or a tad better. I should at least go average my variations so far and change it in the wiki page.
Winter daily driver, parked most days right now
Summer daily driver
Old 11-10-2008, 10:24 PM   #6 (permalink)
jeepin xj (pro jeep ecomodder/hypermiler) - '95 CHEROKEE XJ
Last 3: 21.58 mpg (US)
If you build me one for my 95 jeep cherokee 4.0 6cyl ill buy it, it does have a digital or electronic vss, and i know where all wires are for each injector which are 228cc 43.5psi max, right now psi is 38 or 39 so they flow 220cc approx. at 22psi and are all 16ohms
8000 pulses, no cruise control
build me one and ill buy it, her is my email justinta@verizon.net
Old 11-19-2008, 09:28 PM   #7 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Aveo5 SV
90 day: 30.55 mpg (US)
what do you mean by "practice P & G"?
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
Old 11-19-2008, 11:34 PM   #8 (permalink)
Addicted
bbjsw10's Avatar
P&G= Pulse and Glide MetroMpg did an excellent write up of it at that link.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly) MetroMPG OpenGauge / MPGuino FE computer 12 10-11-2009 04:29 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
Pulse and Glide finally showing progress bbjsw10 Success Stories 22 11-30-2008 06:51 PM
speed on mpguino fluctuates briansavka OpenGauge / MPGuino FE computer 1 08-01-2008 12:06 PM
