Old 11-01-2008, 06:17 PM   #1 (permalink)
high school
ModelE's Avatar
sabre - '02 LeSabre Custom
90 day: 23.45 mpg (US)
frontier - '04 Frontier XE
90 day: 18.97 mpg (US)
Lightbulb good/best engine block heater?
winters fast approaching in new england soooo i'm looking to invest in a engine block heater. alas, i have no knowledge of good/bad brands, appropriate wattage, etc etc. any and all recommendations and comments are welcome!
Old 11-01-2008, 09:30 PM   #2 (permalink)
I always thought a oil pan heater to be a better heater now that fuel injection dominates cars. It would be an easier mod for you to do to and they generally use less electricity.
Old 11-01-2008, 09:36 PM   #3 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I'd say the best heater is the one that raises the engine temp the highest over ambient. That probably means one in the cooling system.
EDIT: seen this? http://metrompg.com/posts/block-heater.htm
Old 11-02-2008, 10:50 AM   #4 (permalink)
Wicked Wanda - '99 Beetle GLS
90 day: 29.59 mpg (US)
Green Monster - '99 Explorer Sport
90 day: 16.73 mpg (US)
Dad's Taxi - '99 Odyssey EX
90 day: 24.23 mpg (US)
Our company trucks all have the BLUEHEAT sytem. It warms the engine and defrosts the windshield without running the engine. Very nice!
BlueHeat® Main
It's expensive ($1800 installed) and it does use a little gasoline to create the heat.
Old 11-02-2008, 11:20 AM   #5 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
I install these at my work, they are sweet, but as mentioned very pricey.
Here is the one I used, I am very pleased with it. Block heater
I highly recommend reading MetroMpg's documentation of his testing, that guy does his homework. Always has great info.
Temro Zerostart is a good brand as well, used by a lot of OEM's, and fleet companies.
Old 10-30-2010, 02:46 PM   #6 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
Has anyone seen a heater that replaces the oil pan's drain screw?
Piwoslaw's Peugeot 307sw modding thread
Old 10-30-2010, 05:02 PM   #7 (permalink)
Steve's Suzuki - '00 Swift GA
90 day: 51.99 mpg (US)
I've seen the oil drain plug type heater... not on a car though. Some airplanes have them and generally speaking they are too small to heat up the oil very much. Heating pads JB welded to the pan are much better. They heat up the whole engine to 100F+ in a few hours. But that is in an inclosed hangar with an engine cowling that does not let much air out. I think a coolant heater would be a better choice. A coolant heater will warm the inside of the car too.
Old 10-30-2010, 05:08 PM   #8 (permalink)
aero guerrilla
Piwoslaw's Avatar
Diesel
I recently installed a 550W coolant heater, but thought that a 100-150W heater for the oil would also be a good supplement.
Old 10-30-2010, 08:40 PM   #9 (permalink)
UFO
Beetle - '01 Beetle GLS
90 day: 41.77 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
I have a Zerostart coolant heater. I don't think anyone who drives a TDI uses anything else.
"We think B20 is for suckers" N. Cowell, Denver B100
Old 11-01-2010, 01:31 AM   #10 (permalink)
surly teady bear
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
When we lived in western AK (arctic climate) an oil pan heater (jb or high temp silicone) was sufficient to keep oil in a very liquid state without blankets and what not and we were seeing -20* temps. Ideally I like a oil pan heater (glue on type), coolant heater (with a pump is best) a battery blanket or trickle charger, and cabin heater.
Oil pan heater
pro oil is very liquid which means that it will lubricate quickly
con does not warm the rest of the engine much
coolant heater
pro heater core is warm fast, the engine is warm for effecient opperation
con oil may not be heated very well and still thick
Battery blanket or trickle charger keeps the battery topped off in the very cold
Cabin heater is a luxury, but it is nice to have a warmish car to get into.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
block, engine, heater
Civic Block Heater Install TomO DIY / How-to 40 12-14-2010 04:46 PM
2003 Toyota Matrix Block Heater Daox EcoModding Central 23 09-08-2010 02:19 PM
Geo Metro Block Heater How-to bbjsw10 DIY / How-to 75 12-31-2009 01:34 AM
Heat engine block for efficiency? bennelson EcoModding Central 43 08-12-2008 10:45 PM
An Engine Block Heater in San Jose Who EcoModding Central 20 07-28-2008 06:44 PM
