Definitely review all the tips mentioned. Some will strike your fancy. Some won't. Do what you can.
Check your tire pressure. Easy, free, often measurable results on the first tank. I like to run mine at the sidewall rated pressure, +3.
How fast do you drive?
Does it have a bed cap? How would you feel about building a simple one for around fifty bucks?
Keep us posted.
troy
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
