Old 05-01-2011, 04:28 PM   #71 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
I CAN'T WAIT for you to drive that thing around.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
Old 05-01-2011, 07:36 PM   #72 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Almost there !
Keep up the good work !
Lifetime fuel consumption :
Old 05-02-2011, 02:22 PM   #73 (permalink)
jackbauer's Avatar
Little video update. I didn't get to spin up the motors today due to getting bogged down with fitting the 12v battery and sorting the led lights.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
www.evcbr.com
Old 05-12-2011, 03:37 PM   #74 (permalink)
jackbauer's Avatar
Tested the traction systems this evening. All good so far. Need to start thinking battery pack and charger soon ........
www.evbmw.com
www.evcbr.com
The Following User Says Thank You to jackbauer For This Useful Post:
euromodder (05-13-2011)
Old 05-12-2011, 04:37 PM   #75 (permalink)
PaulH
Very Very nice Jack!!! So clean and beautiful!!! I bet you are tempted to go take a little test drive. That's going to be fun.
Old 05-19-2011, 02:20 PM   #76 (permalink)
jackbauer's Avatar
Soooo anyway decided to try out something i'd been thinking about since starting the pipe heating and bending for the bike frame. Could i pass a few thousand amps through the steel pipe and use electricity to heat it up for forming? Then answer seems to be yes.
www.evbmw.com
www.evcbr.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
BamZipPow (06-28-2011), dcb (05-20-2011)
Old 05-19-2011, 03:03 PM   #77 (permalink)
jackbauer's Avatar
The heat is on :
www.evbmw.com
www.evcbr.com
Old 05-20-2011, 01:57 PM   #78 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
fyi, on the pipe input power from the wall you averaged about 3476 watts (15.8 amps @220V) per second for the first 136 seconds of heating time.
Old 06-11-2011, 11:26 AM   #79 (permalink)
jackbauer's Avatar
So i finally got around to some more work on the bike. Built up a 96v polymer pack and hit the gas :
The first rather whimpy attempt was at 100amps battery current. I ramped it up to 150 amps for take 2. The bouncing was caused by the battery current limit kicking in and out.
www.evbmw.com
www.evcbr.com
Old 06-11-2011, 02:10 PM   #80 (permalink)
euromodder's Avatar
Diesel
Great !
The next big leap is taking it out on the road, I'd guess ?
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
1993 Honda Del Sol conversion delsolectric Fossil Fuel Free 5 06-09-2009 12:18 PM
Honda CRX good for conversion? resestop Fossil Fuel Free 10 05-08-2009 09:10 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Conversion: 91 Honda Accord w/ HHO anox195 EcoModding Central 36 08-21-2008 07:00 PM
