Old 07-14-2009, 07:00 PM   #21 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
... which is normal (pull from N to D for column shift). The potential hazard there is if you shift from N into a forward gear that's too low for your current road speed.
Old 07-14-2009, 07:02 PM   #22 (permalink)
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
My Escort's shifter reads P-R-N-OD-D-L. One time I had shifted into D for engine braking and forgot to put it back into OD. I was approaching a hill at a little over 40 mph and wanted to bump the trans out of OD so I pulled the shifter down a notch, not realizing it was already in D. Remember there's no 2 on the shifter so it went straight for first gear, which redlines at 38 mph. Some cars will simply not engage a gear if it will over-rev the engine, but apparently my Escort doesn't have this feature. I felt the trans reach for first gear and felt the car start to lurch, and I realized what happened and bumped the shifter back before the engine zinged right past the redline. I've forgotten to put the shifter back to OD from D many times but that's the only time I've ever done that.
In a related story, a manual equipped car is in the works.
More choices...
Old 07-14-2009, 07:05 PM   #23 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '010 Agility 125
Modern cars won't downshift if it will overrev the engine. You can, however, throw the drive wheels into a skid if it downshifts at very high RPM and you're on icy or wet roads.
Old 07-14-2009, 07:33 PM   #24 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Chrysler hydraulic transmissions won't (that I know of) engage first gear at anything over a certain speed, since the gear is equipped with a "sprag" clutch, which allows it to freewheel any time there is no force on the input shaft.
Old 07-14-2009, 10:31 PM   #25 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Originally Posted by cfg83 View Post
Hello -
Maybe dumb thing to say, but this safety feature ONLY applies to modern automatics, right? Manuals can still self-destruct at the whim of the driver, yes?
I'm asking because I "like" to think of reverse as my last best hope for stopping in a situation where my brakes have failed. No tranny left, but won't fly over a cliff either.
CarloSW2
My Subaru, my Honda, and other 5MTs I've driven, have an interlock. As you're rowing through the gears, it won't let you go from 5th directly to R. You have to go 5, N (center the stick), R. And yeah, it'll let you spin the engine backwards if you really want to, or spin the engine at 20000 RPM until it grenades, or both. But no, there's no point in engine braking like that. Engine braking in forward gears works very well as long as you're going faster than idle. Slower than that, I suppose you could shift into R, give it throttle, and feather the clutch. No damage done to the tranny or engine.
Teardrop aerodynamics... in reverse! Piwoslaw Aerodynamics 116 02-27-2012 04:53 AM
Registering a car based reverse trike in CA Carwhisperer EcoModding Central 58 07-10-2011 07:12 AM
HyperRocket: hot looking 125mpg reverse trike on Ebay HyperRocket For Sale 53 05-31-2011 04:10 PM
I just witnessed a car accident! SVOboy The Lounge 18 02-08-2008 08:41 PM
Reverse drafting: how to slow down on the hwy and not hold up traffic MetroMPG Hypermiling / EcoDriver's Ed 20 02-04-2008 01:16 AM
