Old 12-19-2008, 04:09 PM   #11 (permalink)
Wannabe greenie
The Clunker - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Originally Posted by wikityler View Post
I did this with my acclaim. I found that the dmm I was using, having 1/2 second measurement, wasn't responsive enough. Something a bit faster, and it would work great.
What about an analog multimeter?
Old 12-19-2008, 07:05 PM   #12 (permalink)
Most MAPs have voltage outputs. I'm sure some maker somewhere thought they'd be smart and put in a frequency output on something though.
And many modern multimeters also measure frequency. But if it outputs a frequency in the audible range, there's an even better way. Tap into the signal with a series resistor and capacitor and connect it to a very cheap audio amplifier. Then just listen to the tone while driving.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 12-22-2008, 11:18 AM   #13 (permalink)
Tracy - '00 corsa
is a MAP sensor the same as a MAF sensor? Mass Air Flow sensor? if not what would measuring a MAF tell you?
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 12-22-2008, 03:57 PM   #14 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Firefly 3dr
90 day: 40.08 mpg (US)
Map is Manifold Air Pressure. It's like an electronic vacuum gauge. MAF is Mass Air Flow, it measures the quantity of air entering the intake.
Old 12-22-2008, 05:11 PM   #15 (permalink)
The Crimson Crawler - '04 Elantra GLS
90 day: 36.71 mpg (US)
I thought it was Manifold Absolute Pressure?
Old 12-22-2008, 08:32 PM   #16 (permalink)
1988 Ford Escort Pony - '88 Escort Pony
90 day: 39.88 mpg (US)
1997 Ford Escort Station Wagon - '97 Escort LX Station Wagon
90 day: 39.4 mpg (US)
Lil Red - '88 Escort GL
90 day: 32.23 mpg (US)
Correct
Old 12-24-2008, 04:23 PM   #17 (permalink)
Tracy - '00 corsa
does voltage of MAF sensor indicate the engine load?
Old 12-26-2008, 07:06 PM   #18 (permalink)
Turbo gas guzzler
grocery getter - '03 Evolution
90 day: 17.55 mpg (US)
not really, it measures the volume of air entering the engine. this can be used as well, since the less air the engine is sucking in the less fuel it is adding to the engine. Problem is MAFs use a hertz reading which is more difficult to monitor.
Old 12-30-2008, 04:56 PM   #19 (permalink)
Tracy - '00 corsa
my BOSCH MAF gives a voltage signal 0-5v. this is calibrated to air flow rate which is directly proportional to fuel flow rate. boscheSensors (page 57)
all we need do is data log voltage and speed and we have a method of calculating MPG. or alternatively you could just display the voltage on a meter and do the mpg calculations in your head! at constant speed you know what voltage to expect, if mods reduce the voltage then you know they save fuel.
Old 12-30-2008, 04:58 PM   #20 (permalink)
Tracy - '00 corsa
can a sat nav be set up to display trip average speed?
Best spark plugs / wires with FE in mind? noopy7 EcoModding Central 12 10-29-2010 04:18 PM
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 04:53 AM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 07:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
no vacuum for vacuum gauge? modmonster Instrumentation 2 11-07-2008 08:40 PM
