I am planning on helping a relative mod is Kia soul to add a kill switch for it.
I found the Fuel injector fuse in the block but its a short min blade fuse and I cannot find a fuse with leads for it. I want to add a NC relay and run a switch into the cab for manual activation as desired.
Any ideas on how to get the fuse terminals into wire leads?
I also can put a relay inline right at the fuel injectors but I would have to do a relay for each one. I prefer to keep the engine bay wires intact if i can.
Here is a diagram I found on the web. If i do the fuse block its killing the bold "2" fuse:
Ideas?
![](http://ww2.justanswer.com/uploads/ebrock63/2010-01-19_182201_2010-01-19_111721.png)
