Old 09-04-2008, 01:57 PM   #91 (permalink)
Red Beast - '82 V45 Sabre Vetter Fairing
90 day: 39.38 mpg (US)
The Wife's bike - '82 CM450E Red
90 day: 57.22 mpg (US)
Yellow Submarine - '04 Neon SXT
90 day: 28.71 mpg (US)
reading through the thread, it seems that you are forgetting the MPGuino as the computer. same code, a couple of diffrent variables (the same ones that you would have to work out for any other vehicle). now just to get a broad range fuel flow sensor. max rate 6 GPH, maximum low rate of 0.25 GPH. this would give you cruising MPG, what you are really trying to monitor.
speed sensor could be a hall effect monitor on the bach of your speedometer.
more later.
p.s. conductiity with gas? are you NUTS!
Old 09-12-2008, 05:45 PM   #92 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
this thread started before the MPGuino got really rolling and hopefully encouraged it's development. it was all tried in the 70's but we didn't have the neat electronics, like the MPGuino. the electronics have gotten more economical, but the inexpensive flow meter remains elusive.
Old 10-05-2008, 01:55 AM   #93 (permalink)
For those looking for a mileage computer for a carbureted engine, I'm selling a few brand new Compucruise 44 kits. I also have the FWD kits for them. Details are in the classifieds.
Old 10-05-2008, 04:45 PM   #94 (permalink)
I was looking online, and I think I found something that might work (Modded of course.) LowranceNet electronic fuel flow sensor
Old 10-05-2008, 05:54 PM   #95 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I couldn't find any specs on that on ac7ss. Like what is the range? Given it is for motorboats with 150 gallon tanks it might not register a motorbike idling, might need to be in 1.5 gph land to get it to spin.
How accurate is the compucruise and at what flow ranges clbolt?
Old 10-05-2008, 07:22 PM   #96 (permalink)
I don't know how accurate it is or what the flow ranges are, I couldn't find any published specs on it. However, from what I've read, they work well if the flow sensor is properly placed. Since you also have to calibrate the unit to your car as far as mileage and fuel capacity, it'd be sensitive to how accurate you were in the calibration. I'm thinking that using a GPS to set up the mileage would make it pretty accurate.
Old 10-06-2008, 12:02 AM   #97 (permalink)
I could not find it anywhere else! On my truck, I figure idling is at 0.55gph. the only way to be less than that in DFCO. This was the only thing I could find in an EXTENSIVE search that was less than us$150.
Old 10-06-2008, 08:24 AM   #98 (permalink)
dcb
needs more cowbell
dcb's Avatar
We had found this sensor earlier, they are hard to find though.
the low end is about 0.396 gph and the high end is about 39.6 gph.
I don't think I've seen the metro exceed 2 gph Though if you wired the injector open it would be about 7.2 gph. And the bike uses less than that.
Originally Posted by dcb View Post
Ya, das Durchflußgeber ~$61 Conrad Electronic - Europas führendes Versandhandelsunternehmen für Elektronik und Technik
The low end of the flow wasn't small enough for my liking
0.025 - 2.5 l/min
Auf.
Old 10-06-2008, 01:24 PM   #99 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Originally Posted by marthyj View Post
Hi there dude. How's everything going right there. Actually, I am waiting for the feedback of your DYI flowmaster. How is it now?
Actually I havent tried it. My cars are FI so the mpguino by itself works for me. I was just suggesting a thought for anyone who wanted to try it.
Winter daily driver, parked most days right now
Summer daily driver
Old 10-06-2008, 10:41 PM   #100 (permalink)
SuperMID designer
Yoshi's Avatar
Found the product page.
EP-10 Fuel Flow | Lowrance
It says 0.6-45 Gal/hr.
We need an NMEA 2000 display device to read the data.
Yoshi
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 01:09 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 09:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
