Old 11-28-2010, 10:38 AM   #1 (permalink)
Sweetie - '011 Sonata GLS
90 day: 37.06 mpg (US)
HONKR - '94 KLX686
90 day: 59.94 mpg (US)
Odometer vs GPS
I recently found that my odometer is reading 2.65 miles low compared to the GPS for a 100 mile trip. Which would you trust to do your mpg averages?
Old 11-28-2010, 11:11 AM   #2 (permalink)
I would trust the GPS. IF you can find the specs on your unit, it's probably accurate to within something like 15 meters total point to point. If you didn't hit any resets or move without the unit on, it should be the best way to measure distance covered. I found my Jetta odometer reads 10% high, which was a little disappointing, but its good to know the truth
Old 11-28-2010, 11:46 AM   #3 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
GPS.
Odometer varies with tyre size, tyre wear.
Lifetime fuel consumption :
Old 11-28-2010, 11:53 AM   #4 (permalink)
HONKR - '94 KLX686
Well it's been good to know that my average is actually better than calculated by around 1mpg.
Old 11-28-2010, 01:15 PM   #5 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
not even a question. the gps.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 11-29-2010, 12:04 AM   #6 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
I have a MPGuino that is calibrated to a GPS distance. The diffrince between the GPS/Guino vs the Odometer is pretty consistent so I have a conversion factor for the odometer to be used when the guino's power gets interrupted.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 11-29-2010, 11:44 AM   #7 (permalink)
Lil Sulf - '94 Corolla
90 day: 47.62 mpg (US)
GPS, because every time I turn my engine off with coasting, there is about 1-2 seconds where the ODO does not record any movement. Over a 400 mile tank with heavy P&G I can end up 15 miles off (low) if I trust my ODO instead of GPS.
And that's without a Scangauge o.O
Old 11-29-2010, 12:29 PM   #8 (permalink)
I have a question about how a GPS calculates miles. Does it use a "true projection" like a map distance does, thus flattening out hills and valleys? Or does it calculate the actual distance traveled through the valleys and over the hills?
Around here the terrain is so flat that it would make little difference, but in northern GA's hills it could add up to a percent or two.
I know that there is 1.5 mile difference between my morning commute and the evening drive. How can that be when I start and end my trips at the same points? The answer is the highway interchanges that I go through. On my way to work I go through the inside curve and on the way home I have to go around the outside of the intersection. You wouldn't think such a little thing would make a difference, but we all know it's the little things that add up.
Just because your GPS and you odometer read different distances doesn't necessarily mean that either are wrong. They may be measuring different things.
Old 11-29-2010, 12:42 PM   #9 (permalink)
Every second or so your GPS calculates position XY and Z. Their is usually some error lat/long and a fair bit more for altitude. If you are stopped your Odometer will note that, but the error in the position calculations will add up. Best I can come up with is check your GPS vs your Odo for a couple different routes, at speed. Then compare both to a measured distance.
Old 11-29-2010, 02:22 PM   #10 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...it's a three-dimensional (lat, long and alt) "TIME" sphere, which measures the "TIME" from each satellite to your receiver to determine your location.
...GPS (used to be called NAVSTAR) is a digital, high (very high!) tech, 3-dimensional, version of the old two-dimensional Navy/Maritime LORAN systems.
Using Google Earth to measure odometer accuracy MetroMPG DIY / How-to 10 07-12-2011 03:38 PM
GPS help Varn Off-Topic Tech 17 11-23-2010 10:31 PM
Checked your odometer, lately? NeilBlanchard DIY / How-to 22 01-01-2010 11:02 PM
Odometer Accuracy for tracking mileage COcyclist Instrumentation 5 12-02-2009 07:22 PM
