Old 10-20-2009, 12:06 AM   #2471 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
different values of what? I'm confused! hahaha.
signature goes here.
Old 10-20-2009, 03:50 AM   #2472 (permalink)
jackbauer's Avatar
different values of t-pos and t-gain?
Old 10-20-2009, 07:41 AM   #2473 (permalink)
PaulH
As long as throttle_gain is 8 more than the pwm_gain each time.
Old 10-20-2009, 05:08 PM   #2474 (permalink)
Howdy,
Been enjoying this thread for a while. Finally ordered a kit today. Going to run it in a 1974 Citicar. Can't wait! If anyone else is building a controller in Austin, Tx., feel free to PM me.
Old 10-20-2009, 06:02 PM   #2475 (permalink)
PaulH
Yo! xtian999! Wazzzzzzzzzzzzzaaaaaapppp! You are going to run it in a citicar?! Aweosme! I am guessing 0-60 in like 1 second if you can get 144v, since it looks so dang light. I can't wait to see how it turns out! ya!!!
Old 10-20-2009, 07:14 PM   #2476 (permalink)
Yeah, It still has the stock 6.5 hp serial-wound motor with only 3K miles on it. Since that will be the weakest link, I am looking forward to replacing it with ???. Actually, if you could suggest a motor that will use the full capabilities of your controller, we can see just how quick/fast a Citi can go.
The stock diff will probably go away at some point, so don't let that limit the choices.
Thanks,
Xtian
Old 10-20-2009, 08:06 PM   #2477 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Thanks,
Xtian
Citicars become relatively unstable over 50mph, my commuta I have had up to 65mph ish going downhill with no regrets. If you really do have a citicar and not a commutacar and you plan on driving freeway speeds I would recommend moving the rearend differential back so you don't pop wheelies on the freeway cement pieces. Even my comuta with its longer wheelbase will start rocking after a while on a cement freeway if I don't coarse correct into a crack every once and a while.
Stock wise comutas running 72v can typically go 45-55mph depending on motor, tires, etc.
The only motor I know of that upgrades a comuta (or citi) is made by D&D, if you call and talk to them you can find out the largest for your car.
Supposedly the motor in my comuta (from D&D) can be overvolted up to 120v from the rated 72v but you need massive cooling and I would estimate the life of the motor is decreased.
Cheers
Ryan
Old 10-20-2009, 08:42 PM   #2478 (permalink)
What's wrong with a few wheelies?
Old 10-20-2009, 09:03 PM   #2479 (permalink)
rmay635703's Avatar
On my car when I would get all 4 wheels off the ground over the railroad tracks sometimes the seat would slide forward and I would end up slumped down like a midget and usually end up stopping to move my seat position.
That and its also hard to steering with your car doing the Mexican pimp car action down the freeway
Old 10-20-2009, 11:14 PM   #2480 (permalink)
What's wrong with pimpin"?
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 672 02-10-2012 05:41 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 527 09-02-2011 03:35 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
