Old 08-30-2008, 03:35 PM   #1 (permalink)
Preventing ScanGaugeII from going to sleep
Issue: Narcoleptic ScanGauge— Kill switch doesn't keep SGII alive when engine off coasting.
Ok, I know this has been discussed here and elsewhere but I'm still unable to solve my problem.
I successfully installed a kill switch in my Metro; much appreciation goes to "bbjsw10" too, btw. Obviously, having a kill switch solves all the fumbling around with the ignition/key but in theory (bypassing the standard ignition switch) I should be able to keep the SGII alive. However, mine still goes to sleep after a few seconds.
I've tried the 'hybrid' setting with no change. Are there any other criteria I could change? I doubt if it matters but mine's a 96 Metro with the 1.3L.
While I'm at it, I have to give props to "MetroMPG" for starting much of this madness on his site. He's the one that sold me on the ScanGauge in the first place. I'd just like to get the most out of it.
I've learned a lot just from lurking here and there for the last couple years, so thanks very much for all the info.
Patrick
Old 08-31-2008, 12:17 PM   #2 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Patrick
I am also having the same issue, and it is the only thing keeping me from EOC almost all the time. I have perfected the bump start (thanks to well documented descriptions, Darin) and have plans of installing a kill switch in the very near future. Having a solution available, should anything go wrong, to an upcoming project would be great.
Patrick
I also must thank Darin for all his efforts on this site and sharing insight into the magical world of hypermiling.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 08-31-2008, 12:55 PM   #3 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
Is the metro still "on" when you hit the kill switch?
Old 08-31-2008, 01:35 PM   #4 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Red's on the right track. The only reason I can think of that the SG would go to sleep is that the power (ignition) is shut off. But I could be wrong - maybe it watches for some combination of signals to tell whether the engine is running or not.
I'd definitely double check that you saved the "hybrid" fuel type first.
Then maybe you should check in with bbjsw10's kill switch thread to see if anyone else is having this problem. Maybe killing the injector is somehow different than interrupting the coil pickup signal (which is how my kill switch is wired).
My SG2 is set as "hybrid", and the kill switch doesn't put it to sleep.
Old 08-31-2008, 05:12 PM   #5 (permalink)
Tupper - '97 SW2
90 day: 37.52 mpg (US)
I think the SG looks for the ECU to turn off..but I could be wrong.
I have my saturn wired up to kill the injectors and my SGII does not go to sleep. I do not have it set to hybrid mode either. Not sure if that will help you or not though. Just make sure your ignition switch is still set to ON when you EOC.
Old 08-31-2008, 05:29 PM   #6 (permalink)
Red
Red's Avatar
Well I'm thinking that for some reason or another KingsX's kill switch is shutting off power to the OBD port making the SG think that the car is off.
Old 08-31-2008, 05:33 PM   #7 (permalink)
Tupper - '97 SW2
if it kills power to the OBD port then the SG will shut off immediately....it is powered directly from that port.
What did you do to wire up the kill switch? which wire are you opening?
Old 09-01-2008, 01:58 PM   #8 (permalink)
Per bbjsw10's kill switch post, I wired mine to cut the injectors, via the injector fuse at the fuse block. I leave the ignition key switch alone, just dropping the car out of gear and then hit the switch. Bump starting, by the way, has always been a rather seamless affair. If I had more than one seat installed, a passenger would likely never know the difference most of the time.
Thanks for all the quick replies— I'm certain I'll eventually get this dialed with all you guys' help.
Old 09-19-2008, 03:48 AM   #9 (permalink)
Well, I still have the problem and it's still frustrating. Anyone with a fresh idea?
Old 09-23-2008, 03:12 PM   #10 (permalink)
ScanGauge sleeps when engine is "off"...
Consider this...when the engine is "off", there is NO input from the injector pump. Nothing. Without an input from this ( or any other engine function) the SC "thinks" it is time to sleep.
The clue you get from the ignition being switched "on", but the starter is not engaged...the SC doesn't wake up. Without input voltages from a running engine, there is nothing for the SC to record. -whitevette
eoc, geo, kill switch, sgii, sleep
ScanGaugeII Throttle Cut Off and MPG Calibration ballegre Instrumentation 9 07-18-2008 02:46 PM
DIY OBDII to ScanGaugeII cable tasdrouille Instrumentation 2 05-12-2008 11:24 AM
WTB: ScanGaugeII NoCO2 For Sale 0 02-04-2008 11:54 PM
