Old 02-27-2008, 01:58 PM   #11 (permalink)
Ecomodding Amateur
krousdb's Avatar
Cold Fusion - '04 Prius
90 day: 67.34 mpg (US)
It will be flush with the bumper. I am using coroplast for the under pan.
Old 02-27-2008, 02:03 PM   #12 (permalink)
bestmapman's Avatar
Did Frank mention anything about the rear wheel skirts.
Old 02-27-2008, 05:32 PM   #13 (permalink)
Ecomodding Amateur
krousdb's Avatar
He did mention rear wheel skirts, but he is trying to get to market with something ASAP. The front grill block will be the easiest and quickest. I think his next project will be decided by whatever mod has the highest level of interest by those on this site and others. Why not reassert your interest on the hybrideffects thread.
Old 02-27-2008, 09:18 PM   #14 (permalink)
- - '010 Prius III w/Navi
Hi krousdb,
What is coroplast made from ? What is $100 a barrel now ? Maybe that is why its twice as much. I think we need to move to a future where petroleum is not burned and only used for plastics. That way, its sequestered. Like it was in the ground for many years.
Old 03-01-2008, 04:37 PM   #15 (permalink)
Ecomodding Amateur
krousdb's Avatar
Ran out of coroplast, again!
Full drivers side belly pan. 2/3 passenger side, missing middle 1/3.
RH Mirror Delete
Ready for bondo on the inside. Need to go get some later tonight. Once the inside is filled in, I wall add bondo to the outside to build up the contour. Then sand, primer sand and paint.
Old 03-01-2008, 05:41 PM   #16 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Are you planning to cover more? If I recall, when you did the VX and Del Sol, you covered everything, but left a channel/gap where the exhaust was routed.
Old 03-01-2008, 05:45 PM   #17 (permalink)
Ecomodding Amateur
krousdb's Avatar
Yes, just need to convince my wife to get more. The store closes before I get home from work and they are not open on weekends. I guess you don't need to be open much if you can get someone to pay $30 for a 4x8 sheet.
Old 03-01-2008, 06:09 PM   #18 (permalink)
LUVMY02CREW's Avatar
TANK the fifth - '02 S10 Crew Cab 4x4 LS
90 day: 20.13 mpg (US)
Looking very good
Maybe I missed it somewhere, but are those just sheet metal type screws holding it all on?
And, how much of an issue will it be to you when you have to remove this for some type of regular mtce/repairs?
Old 03-08-2008, 07:27 PM   #19 (permalink)
Ecomodding Amateur
krousdb's Avatar
Yes they are sheetmetal screws. I will have to remove for inspection and oil changes.
Finished the RH Mirror delete last weekened.
Old 03-08-2008, 07:55 PM   #20 (permalink)
Looks slick, Dan.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/prius-aero-mods-undertrays-grille-block-mirror-delete-1073.html
Posted By For Type Date
Efecto Magnus en el smart roadster? This thread Refback 01-24-2012 08:47 AM
smarteros.com This thread Refback 09-08-2010 08:58 AM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
How does a grille block improve warmup time? fanamingo EcoModding Central 30 05-03-2010 06:13 PM
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 7 01-31-2010 12:21 AM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 11:14 AM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 08:46 AM
