10-10-2012, 01:24 AM
#621 (permalink)
Originally Posted by arcosine
Maybe you misunderstand my comment. Rock wool is dusty and will get into the air filter and clog it. Rock wool not good, they use air blowers to put it in the attic, imagine it blowing around the engine compartment. :P
My engine at least takes air outside of engine bay (diy ram air, turbo diesel), can't see how it could go against wind to ahead of car to be able to enter to filter. Might not work with everyone, also there might be bit different kind of rockwools too, ones I have here I can lift from other end as it is quite stiff stuff.
10-10-2012, 03:39 AM
#622 (permalink)
I'm using something like a blanket that is for extinguishing fire to keep my engine warm. It's made of glass fibers and it won't melt or burn even when touching exchaust.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
10-16-2012, 06:45 PM
#623 (permalink)
Went to a local get together with my car club... someone took a picture of it. When you're parked near BMW 2002's, diesel Mk1 Rabbits/Caddys and a mint Audi Sport Quattro I'd call that an accomplishment.
(Of course I got kicked out of the main parking lot... apparently they didn't see "TATRA" written on the hood  )
I get to use my dad's car this week so it's time to pull off my belly pan and add an air dam. The pan's C-channel structure had bent and snapped at a screw hole and was hanging down. It's too much trouble.
Also, oil change!
10-16-2012, 06:53 PM
#624 (permalink)
Coroplast Engineer
Please tell if you end up going to lspr in houghton. I have a friend who lives up there.
Originally Posted by Tango Charlie
You know how when you buy a car, and then you start noticing how many others there are on the road? Yeah, that doesn't happen with a 1st gen Insight.
AV Build Thread
10-17-2012, 06:51 AM
#625 (permalink)
All hail Dad . . the young mans reserve account! Thank him for us.
10-17-2012, 07:40 AM
#626 (permalink)
Master Ecomadman
Looks like the car had some action, an alien fusion beam has vaporized a hole in the door. A piece of duct tape would cover this defect and disallow dust from entering the cockpit and crew compartment.
- Tony
10-18-2012, 05:44 PM
#627 (permalink)
Well, I also have to do horse chores three times a day for eight days straight, so it all evens out.
Had duct tape over the laser hole but it ended up being more trouble than it was worth. Besides I have bigger problems than dust infiltration... mainly tie rod ends, suspension bushings, a wheel bearing and rotting frame rails.
Yup, planning to arrive between 5-6pm on Thursday for the volunteer meeting in Houghton.
_MG_1495 by Tyler Linner, on Flickr
10-18-2012, 10:30 PM
#628 (permalink)
I like Dad even more
10-19-2012, 08:18 AM
#629 (permalink)
Master Ecomadman
Yey 40 mpg! Can you open the hatch?
- Tony
10-19-2012, 01:30 PM
#630 (permalink)
It wouldn't be so bad if the the one wasn't a complete douche, trying to steal others' food. And they all hate the new hay so every day they spread it around and **** on it. Then I have to clean it up (And not feed so much out the next time).
Yes
The Following User Says Thank You to Sven7 For This Useful Post:
