Old 09-07-2010, 07:52 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Got soul?
Soulster's Avatar
Soulster - '010 Soul Plus
90 day: 35.36 mpg (US)
100k POS - '01 Neon
Soul Help (Grill block)
Put on the grill block for aero testing:
So it does look statistically speaking it does do some aero help 0.35mpg whoopeeeeee... I'm sure it helps warm the car up faster in the morning, but how do test that for MPG improvement? I've watched the scan gauge and it shaved 2miles off the warm up time so it's doing something... But I have no clue as to MPG testing. Any Ideas?
Old 09-07-2010, 08:28 PM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
1% gain is better than none!
For a free mod, my colorplast, paint, screws, and help that is not bad. My grill block gets me .71MPG or 1.55%. You have a flatter front end so I would expect yours to be less (also a smaller opening).
Old 09-07-2010, 09:02 PM   #3 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
I think I measured 2 to 3 percent improvement after the upper grill block. I also blocked some foglight openings.
More testing!
Nissan Versa Aeromods
Old 09-07-2010, 09:15 PM   #4 (permalink)
Wiki Mod
More testing!
Can you add your data to the Wiki? We are always looking for more data for the mods.
Grill block partial or full - EcoModder
Old 09-08-2010, 08:36 AM   #5 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
What sort of data do you accept ?
I don't do ABA-style or coastdown testing.
But with the grille block added I immediately saw improvements compared to my "known" FC on the level stretches of my normal commute.
Lifetime fuel consumption :
Old 09-08-2010, 08:43 AM   #6 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Very interesting. That is a small grill block though, I wouldn't expect too much from it.
It makes me wonder what mine is really worth, its a little bigger.
Old 09-08-2010, 10:25 AM   #7 (permalink)
Wiki Mod
Both of those are best, but we will take your type as well. Just note the method you used to acquire the data.'
Example:
2% gain (1.2MPG). data gotten from differences in SG read out in known steady state locations and is consistent over time.
Old 09-08-2010, 10:27 AM   #8 (permalink)
Wiki Mod
Doax: any ABA testing? yours should show up nicely in testing And give some nice data for the wiki
Old 05-30-2011, 02:19 PM   #9 (permalink)
Racer XD - '06 Elantra GT
90 day: 35.42 mpg (US)
Have you tried making a lower grill block? My girlfriend drives your same car and I was looking at making a grill block for her car. I was going to start with the lower grill and see how that worked out. I like the look of yours.
Do you have pictures of how you mounted it to the grill?
I have 2 sheets of black coraplast so I will not have to paint mine.
And with the grill block how did you temps change? Have you drove it in hot weather to see temps as well?
2006 Hyundai Elantra GT 2.0L (Manual)
Weapon-R secret weapon intake with ram air kit ScanGauge Belly Pan
http://www.cars.com/ City 27 mpg - Highway 34 mpg
http://www.fueleconomy.gov/ City 23 mpg - Highway 31 mpg - Combined 26 mpg
Old 10-12-2011, 11:35 PM   #10 (permalink)
Got soul?
Soulster's Avatar
100k POS - '01 Neon
Sorry for the insanely long delay in response...I haven't been eco modding for the past 6 months and as such I haven't logged onto this site. Now that I am in an aerodynamics class I think it would be fun to apply some of the in class knowledge to the real world!
Anyways in answer to your question, I blocked the lower grill with a piece of foam so that it was flush (just over sized it slightly and pressed it into place.) It worked quite well in conjunction with the upper grill in temps less than 30F after that the lower block needed removal and after 40F I removed both (temps were hitting 212F after 15-18miles of expressway, at lower ambient temp it stayed steady at 203F)
Have you done any other mods? I'm thinking about making a front air dam and possibly a removable boat tail...thoughts?
kia, soul
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
How to: Kia Soul front grill block (my first mod :) ) Soulster Aerodynamics 9 05-06-2011 04:31 PM
Grill Block Summary 4536 Aerodynamics 19 07-22-2010 11:55 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
