Old 12-26-2009, 11:54 PM   #1 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 20.27 mpg (US)
Starting ideas for a permanent grille block
When and if winter finally gets to Michigan, that means it won't be too long until the ice is gone and I will be putting my "nice" bumper back on.
I'm trying to think of a good grille block solution that is:
1. Cheap/Inexpensive
2. Easily removable OR invisible
3. Will NOT harm the paint at all
So far my ideas are either put a coroplast block behind the upper grille? Although not sure this will help at all... the upper grille is inset pretty far:
Or build an air dam for the front and put foam weatherstripping on the back so it won't damage the paint... although not sure how I would attach it. The fronts of the sidemarkers have screws in them, and I already have extra-long screws in there to hold on my current air-dam, so that would be one option but idk how I would attach it across the front.
Any ideas?
Old 12-27-2009, 12:06 AM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Drawing a blank...
Old 12-27-2009, 01:30 AM   #3 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
get a closer pic of the front grille. at about 45%. stand off to the side so i can see some deminsion.
Old 12-27-2009, 05:16 AM   #4 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Git some foam rubber and cut it down so it fits snugly into yer open grill slot. Attach yer coroplast front to that and insert it into yer grill slot.
Make the cover into a big Ford emblem.
Old 12-27-2009, 08:00 AM   #5 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
zip tie on a piece of chloroplast, could be on the front or behind the grill.
Old 12-27-2009, 11:16 AM   #6 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
@mcrews Here is a better photo:
If you click on it, you will go to my photobucket which has tons of photos.
@BamZipPow I'm not really sure I understand... ?
@Weather Spotter I tried having coroplast on the outside of the grille and it does scratch the paint
Old 12-27-2009, 12:06 PM   #7 (permalink)
I thought there was already a thread on this topic. Just put some plastic in the oval and call it a day.
Why do you care if it scratches? You replaced your original bumper with a non matching white one. Are you planning to paint the whole car white?
Old 12-27-2009, 12:11 PM   #8 (permalink)
Wiki Mod
you could put rubber on the edges of the chloroplast (silicone, a gasket, liquid electric tape, etc)
Old 12-27-2009, 01:28 PM   #9 (permalink)
mcrews's Avatar
where is a close up.
they way to do it is to make athe oval with reg poster paper....don't use something still, it wont follow the curves. you openin is slightly 3d. I would cut to just hit the edges.
you can buy coloerd electrian tape.
Since the grille block will only touch the edges, if it was me. I'd pop of the logo and get some thing round and hollow (toilet paper roll comes to mind) to brabe the center of the block to the grille. THen I would super glue the logo to the clear grille
Old 12-27-2009, 03:51 PM   #10 (permalink)
I'm new to this forum, and I just finished installing grille blocks and a large, front underside deflector for my new Aveo. What I utilized was aluminum trim coil, which is used as a siding material for homes.
I'll be posting photos soon on the project. The end result can be professional looking and even undetectable if you cut it exactly and can attach it using existing hardware mounting points.
The Following User Says Thank You to Thymeclock For This Useful Post:
Sean T. (12-28-2009)
Removable grille block? Any ideas? Sean T. Aerodynamics 26 08-19-2009 10:05 PM
2000 Caravan grille block: is it for me? Christ General Efficiency Discussion 1 04-15-2009 09:49 PM
Partial grille block - Fully duct tape jesse.rizzo Aerodynamics 12 02-18-2009 05:12 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
