Old 01-10-2008, 02:38 PM   #1 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
Test: 250w electric bicycle efficiency = 1512 MPG equivalent
The best efficiency I've been able to squeeze from the ForkenSwift so far this winter is 107.7 equivalent MPG (US), or 311.5 Watt hours / mile if you speak EV.
bennelson says an efficient run on his electric Kawasaki motorcycle is 15 miles and about 1 kWh to recharge. That works out to 67 Wh/mi, or 503 eMPG, by my formula.
I've been wondering how an electric bicycle compares to these. So I went for an 8.7 km spin on the 250 Watt electric Schwinn. No pedalling. Top speed seen was about 28 km/h (17 mph) - but it's more like 22 km/h (14 mph) on the level.
It's recharging now. I'll post back later with the results.
Old 01-10-2008, 03:19 PM   #2 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 67.16 mpg (US)
Daox's Prius - '04 Prius
90 day: 52.66 mpg (US)
You big tease.
BTW, what is your formula for calculating equivalent mpg?
EcoRenovator.org - Efficient living and green home improvement
Prius Build Thread
Paseo Build Thread
Old 01-10-2008, 03:22 PM   #3 (permalink)
Conversions:
1 kWh = 3412 BTU
1 gal (US) gasoline = 114,500 BTU
EDIT: and the electric efficiency figures quoted are energy use "at the wall" (including charging inefficiencies), not just energy drained from the pack.
Old 01-10-2008, 03:34 PM   #4 (permalink)
Who
UnderModded
Pablo - '07 Santa Fe AWD
90 day: 23.62 mpg (US)
How are you measuring the "at the wall" number and how efficient do you think your charger is?
Old 01-10-2008, 03:40 PM   #5 (permalink)
At the wall measurement is from a Kill-a-watt meter.
I'm not really sure how efficient the charger is because I don't have on-board instrumentation to tell me how much I've fed into or drawn from the pack.
EDIT: but I have seen references of 70-80% charger efficiency chucked around.
Old 01-10-2008, 04:17 PM   #6 (permalink)
Oh my...
8.7 km (5.4 miles)
0.12 kWh to recharge
= 22.2 wH/mile
= 1512 MPG (US) equivalent
Old 01-10-2008, 04:26 PM   #7 (permalink)
Note: obviously it's not a direct comparison. The car & motorcycle are faster than the e-bike. So their efficiency is calculated at a higher average speed.
But the imbalance is countered somewhat by the fact that we're comparing the best case efficiencies of the car & motorcycle, vs. a flat-out worst case run on the e-bike.
Yes, I avoided using the brakes as much as possible, but I did not drive for load or accelerate gently to minimize resistance & Peukert losses, as I try to do in the car. No, I pretty much had the twist grip pinned on "GO!!!" for the full 8.7 km.
Also worth noting: if I'd pedalled some, maybe I could have doubled the electric efficiency. Not an option (yet! ) in the ForkenSwift or on the motorbike.
Old 01-10-2008, 04:33 PM   #8 (permalink)
Who
UnderModded
Call some charger mfr.s and ask them if they'd like to provide you with models to test for your EV web site. Then just accidentally lose the best one.
1512? Nice... with lights on or would that have cost 100 MPG?
Old 01-10-2008, 05:52 PM   #9 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
Nice, I'm gonna try to get the wife a little e-scooter sometime. I think I can handle a 500-700mpg equivalent. Much better than her Cavalier is doing...
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 01-10-2008, 06:52 PM   #10 (permalink)
Wienermobile Jr.
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 26.95 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
E-bikes really are insanely efficient!
One thing you do have to watch is what charger you use.
I did some tests on my cycle using a cheapo 1.5A 36V trickle charger that came with my electric bike hub wheel kit. Man does it charger the cycle slow!
However, I also tried charging my batteries with a couple big old "charge your car batter" 12v chargers which were higher amp. They were about HALF as efficient as the little solid-state trickle charger!
A Killawatt is a great device for measuring electric use. I have slain phantom power in my house down to a $30 a month electric bill.
I think measuring power use at the wall is the only fair way to do it, because it builds in charger efficiency into all the equations. This encourages people to use better chargers!
I saw an E-bike that ran off a couple of DeWalt Lion batteries - that was pretty cool too!
Engine efficiency improvement through higher temp thermostat? Lazarus General Efficiency Discussion 13 02-05-2008 12:39 PM
Equivalent MPG of cycling - garage feature? MetroMPG Alternative Transportation 21 12-27-2007 02:57 AM
How my home-built bicycle trailer lowers my MPG MetroMPG Alternative Transportation 8 12-14-2007 02:43 PM
Forkenswift equivalent MPG Lazarus Fossil Fuel Free 6 12-14-2007 12:11 AM
First ride on a recumbent bicycle: BikeE MetroMPG Alternative Transportation 5 11-28-2007 09:48 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
