Old 08-18-2010, 04:29 PM   #1 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
Throttle position indicator circuit
I have several projects that I am working or going to be working on this idea I have had for a while. What I want to do is add a bar of LEDs to show the Throttle Position Sensor (TPS) voltage as a percent. Similar to KITT from Knight Rider KNT2000's Customs and Restoration Parts :: LED Green Gas Pedal LOL. The difference is the lights would be one the dash.
Here is what I know the TPS runs from 0-5v IIRC getting percent from voltage will not be hard as I believe it is linear but can quickly check with my scanner/programmer. I would like to have an extra LED light for each increase in TP% starting at 5,10,15,20,25,50,75,100%. So at 5% 1 LED would be lit at 10% 2 would be lit.
Unfortunately it has been some time since I worked with circuits an I'm having a little trouble figuring out how to get a 0-5v reference to turn on the lights I want. That is where I need some help/guidance.
I want to go for something more simple than a Arduino hoping I can do it with a IC or logic gate. I guess the easiest way to do this would be to use a battery tester or a fuel gauge to give the reading but I would like to have it as a light bar.
Thanks for the help and I will keep everyone posted as I start working on it.
I move at the speed of awesome.
Old 08-18-2010, 04:54 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
My $25 electric scooter had some throttle lights on it, had one chip and a couple resistors and LED. I'll dig through my clutter and see if I can get a part # off the chip.
Old 08-18-2010, 06:17 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
I don't see it now, but it was basically a quad comparator and would light up 4 leds. You could double it up for 8, but you need a voltage divider ladder with taps for each comparitor, and led resistors and LED.
When I think about it an atmega 168 chip (the heart of an arduino) would make a slightly simpler circuit. You could drive like a 20 led display with 20 low power leds, 20 led resistors and 2 voltage divider resistors connected to an analog pin. Tie it into the tps 5v source (if it doesn't complain) and thats about it.
Old 08-19-2010, 11:22 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
also just noticed the UAA170 chip, looks promising:
SCUMARI Technohobby
Old 08-20-2010, 11:46 PM   #5 (permalink)
This should do the job: Dot/Bar Display Driver
The Following User Says Thank You to RuHaSs For This Useful Post:
skyl4rk (08-21-2010)
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Does a given throttle position always mean consistant, predictable fuel usage? KJSatz EcoModding Central 8 08-17-2008 06:50 PM
Throttle sensitivity Formula413 EcoModding Central 13 05-29-2008 04:55 PM
Motorcycle TPS (Throttle Position Sensor) dcb Instrumentation 3 04-28-2008 07:24 PM
Motorcycle TPS (Throttle Position Sensor) dcb Motorcycles / Scooters 3 04-28-2008 07:24 PM
