Old 07-22-2009, 07:28 PM   #11 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
You probably ought to consider a Kammback, too. The shape of your car lends itself quite well to one.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 07-23-2009, 02:16 AM   #12 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Actually, the Aygo (and its twin sisters, Peugeot 107 and Citroen C1) don't have a hatch in the back that would lift with the kammy. Instead, they only have a rear window that hinges up. Maybe the kammback could be attached to that?
Old 07-23-2009, 03:36 AM   #13 (permalink)
Toyota Aygo - '06 Toyota Aygo + +
90 day: 37.13 mpg (US)
Thanks for your help guys. I do like the suggestions that have been made as i have already looked into this when i removed the front bumper a couple of weeks ago.
At first i was planning to remove \ block the two front grills next to the logo on the front. This is avtually where the air intake is located (behind the left one) but i will attach a cold air feed and place it in the lower grill where the radiator gets its air.
The lower grill is already partially blocked on the left hand side but the honeycomb pattern i'm sure is not helping with the air flow so i'm going to smooth over this and help guide the air towards the radiator.
I think i will tackle these first and see how they go as i'll be constructing them out of fibreglass so could take a little while to get right.
I was also thinking about smoothing down the front bumper bits on the corners. Would this help?
Old 07-23-2009, 04:12 AM   #14 (permalink)
I am a renouned expert in ms paint (ha ha) so i have digitally modified the aygo.
Does this look like a good start or not?
Old 07-23-2009, 04:18 AM   #15 (permalink)
aero guerrilla
Piwoslaw's Avatar
How about guiding the air away from the rad? The radiator and its grill are a partial air trap, so directing more air onto it may increase drag. Directing air to the side or top should be better. Also, you could probably cover the other end of the grill, diverting that air to the other side. How much? You'll find out by trial and error. Cover maybe the whole right half with cardboard and drive around with that. If you notice that the temperature is too high and the fan keeps turning on, then shorten the block by 10cm. Mid-summer is the best time for adjusting grill block size.
Old 04-20-2015, 08:57 AM   #16 (permalink)
Aygo Newton - '12 Toyota Aygo Fire
90 day: 62.61 mpg (US)
I just fitted a Kammback to my Aygo, on my drive home from work today I managed to get a new economy record of 81.5mpg (Imp) before my best was 78mpg (Imp)
postimg dot org/gallery/1piah27g6/bee9c971/
I've also got an upper grill block where air is directed over the engine and around where the intake is (the grill block increases Intake air temp and stops fresh cool air getting in, on a long drive the intake temp can get upto 40*C)
The Following User Says Thank You to Mikes1992 For This Useful Post:
aerohead (04-20-2015)
Old 04-20-2015, 08:41 PM   #17 (permalink)
Stream - '16 Volkswagen Jetta
90 day: 33.7 mpg (US)
Here's a little help for your links. (Click for bigger)
The Following User Says Thank You to bentring For This Useful Post:
aerohead (04-21-2015)
Old 04-26-2015, 10:28 AM   #18 (permalink)
Focus - '05 Ford Focus tdci Futura
As far as the intake temp. Ive noticed that between 30c and 40c the engine runs nice. And also i would do an airdam. The kamm looks good too
Old 04-26-2015, 12:04 PM   #19 (permalink)
The PRC.
Tried blocking everything on mine (search for George) and it made naff all difference apart from a slightly quicker warm up. How are you measuring the intake temps as I never saw any different at all in mine, and as the intake is over the engine I doubt you will.
Given how "dirty" the Aygo is underneath in terms of airflow I suspect the Kamm makes no difference at all.
Willing to be convinced though.
Toyota iQ Practically Begging to Come to the U.S. SVOboy EcoModder Blog Discussion 8 06-18-2009 07:55 PM
Toyota Drops Prius Base Price to $21,000 to Compete with Honda Insight SVOboy EcoModder Blog Discussion 5 04-22-2009 12:50 PM
Toyota Ecodrives the New iQ SVOboy EcoModder Blog Discussion 5 02-22-2009 04:47 PM
Review: 2008 Toyota Avalon Touring Edition (32.8 MPG) RH77 General Efficiency Discussion 2 09-04-2008 01:27 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
