Originally Posted by spacemanspif
Does the turbo create much boost while on light throttle cruising? Should only be "boosting" under acceleration for the most part, but running 5psi on a flat highway could increase consumption unless the 1.0 is so weak that it can't sustain 65mph without the turbo's help.
My Scangauge does not show boost, but some of the other guys are using a bluetooth app on their phones and say, that the cars are under boost to some degree most all the time.
The guy doing the experimentation says it is drivable in traffic without boost; just pretty slow. We have also discussed the main drawback of unboosting, besides lack of go; inefficient intake and exhaust, when running NA. Like I said, we will see what his testing shows.
