Old 09-30-2018, 12:44 AM   #28 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Oil pan heater is now wired in with a quick disconnect plug.
I have since ridden the bike with the vacuum gauge sourcing vacuum from cylinders 1 and 4. Idle is hopeless, but once the bike is actually moving the needle steadies out and doesn't wiggle at all. The gauge is also mounted to the bike now, but its kind of ghetto and is hard to see unless I position myself correctly. As D.O.G. pointed out, there isn't much difference between full throttle and other throttle positions while accelerating. I can easily drop to 0.5 In Hg(?) or below when accelerating. When cruising however, the gauge does become useful, and the needle climbs up to around 4-8 In Hg(?). I believe off throttle was around 11. So far I have run two tanks through with the vacuum gauge installed, but I also adopted a new less accurate fillup technique to avoid fuel overflowing out of the cap when riding. Both fillups were at or above 60 MPG, so I have high hopes for this mod.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
