Old 01-01-2019, 06:09 PM   #1 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Latios - SV650SF
Finally I have a fuel injected motorcycle! I got myself a 2008 Suzuki SV650SF. Liquid cooled, fuel injected V-twin, full fairings, twin spark heads, blah blah blah.
The modding begins!
The bike came with what appears to be a Yoshimura full system, but I wanted a catalytic converter, so I ghetto rigged a stock pipe on there. The newer suzuki 650's come with a cat in the midpipe, but my generation has it in the muffler. It looks like crap and leaks exhaust, but it works.I did take it for a ride and confirmed the cat lights off. A gasket and band style clamps should fix the problems until I can get it welded, if I decide to go that route.
I changed the oil and found the same filter situation as I had with my VFR 400, not compatible with a sandwich oil cooler/heater unless you get a special nut that likely no one makes. Threads are part of the block, so I would need a block from a model that came with the cooler/heater to install one.
Some proposed mods:
Engine:
Shorten stock exhaust leaving CAT in place
DL 650 cam swap(put SV exhaust on intake, put DL exhaust on exhaust)?
^Buy all DL cams to match timing easily^
DL 650 intake trumpets
Hotter thermostat from 2003-2006 model
Block radiator partially
Block oil cooler completely
Drivetrain:
17/42 gearing
Michelin Road 5 tires
Brake drag reduction springs
Higher tire pressures
Aero:
Aero front fender(might need front fork swap for options)
Space fairings out at end to ensure complete leg coverage
Rear tire hugger(pyramid?)
Comfort:
Lowered pegs
Tank rubber(also for tank protection)
Better seat
Other: TeeRiver Fuelbot
Hoping to hit 100 MPG!
ID:	25348   Click image for larger version
ID:	25349   Click image for larger version
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following 2 Users Say Thank You to Daschicken For This Useful Post:
jimhs (01-03-2019), jkv357 (01-02-2019)
