Old 08-18-2015, 09:26 AM   #21 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
for what you want I would look for ways to convert it to 4wd. You will get more power to the road and imho less weight penalty comparing to electric motor+battery pack+driver.
some 4wd subarus or hondas used viscous oil clutch to connect rear wheels to engine when slip occured. I am no expert, but this sounds like "plug and play" solution to me, as you do not need to mess with your car ECU, just connect it mechanically - so you should have less problems with connecting it.
Old 08-18-2015, 01:09 PM   #22 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Make it happen for around $5000? Can't have it.
The ImPulse9 motor you're interested in is $1800 already, so you're through two-thirds of your budget on motors alone.
While you're still blue-skying, the ImPulse9 can be had in either rotation. You'll just need to call NetGain and talk to them. And they're reversible in the controllers too, so you can have electrical reverse. But if you have the reverse gear in the conventional transmission, this is not important.
Old 08-23-2015, 06:53 AM   #23 (permalink)
Originally Posted by ciano22 View Post
The other option is using one single powerful electric motor that is double-sided to drive both wheels. This basically means I will have a locked differential, which may not be ideal, but then again, this car is going to be just for straight lines.
Cornering wouldn't be the only problem, the ABS sensors might bug out too.
Old 02-06-2016, 08:09 PM   #24 (permalink)
You could try to find one of these.. https://en.wikipedia.org/wiki/Chevrolet_S-10_EV
There was an article in Grassroots Motorsports a few years ago who my an electric hybrid out of an old MR-2. Put one of theses motors in the front, found some Prius batteries and had an all wheel drive electric hybrid..
Old 02-06-2016, 11:18 PM   #25 (permalink)
https://en.wikipedia.org/wiki/Chevrolet_S-10_EV#Sales
492 produced, possibly 60 that weren't crushed at the end of lease.
Old 02-08-2016, 02:35 PM   #26 (permalink)
Karmann Eclectric
jray3's Avatar
Odysseus - '00 Honda Odyssey
MR BEAN - '12 Mitsubishi i-MiEV SE
Karmann Eclectric - '71 VW Karmann Ghia Electric Conversion
BOB - '87 Ford 250 Lariat ext cab
integration-schmintegration
On projects like this I'm not worried about synching up the electronics between engine management and motor control. The engine will behave like it's going downhill. (Just like operating my ICE pusher trailer behind an EV.) The electric rear axle could be completely independently controlled, preferably with a hand throttle, or if off the same accelerator pedal; through a master switch to enable/disable the Warp drive.
However, I think this car will be too difficult mechanically. On any car it is difficult to put one series motor on each rear wheel unless they are offset by using a gearbox, as there's not enough width for two motors, half shafts, and CV joints, let alone at the right angles. Putting a differential beneath a body that wasn't designed for it might be doable if you don't mind a big hole in the floor.
Also, this dual rear motor approach with one per wheel has been oft discussed, but very rarely implemented on a DIY EV. As I recall, the Tropica was then only series-motored 'production car' to do it, and not particularly well at that.
Polychain belts and their cogged pulleys are noisy.
I'd still love to french a motor into the driveline of a pickup one day. That would be much easier.
2012 Mitsubishi i-MiEV, 112 MPGe
2000 Honda Odyssey
1987 F250 Diesel, 6.9L IDI, goes on anything greasy
1983 Grumman Kurbwatt, 170 kW "Gone Postal" twin
1983 Mazda RX-7 electric, 48 kW car show cruiser
1971 VW Karmann Ghia electric, 300 kW tire-smoker
1965 VW Karmann Ghia cabriolet, 1600cc
Have driven over 100,000 all-electric miles!
The Following User Says Thank You to jray3 For This Useful Post:
mcrews (02-08-2016)
Old 02-08-2016, 04:45 PM   #27 (permalink)
Could you link-ify that please?
I always enjoy seeing the yellow Ghia. What do you think of this?
98lb, 68hp. 10,000rpm single speed at 6.8:1.
When Arcimoto ships the SRK there should be replacement crate motors available. It has a similar single-speed drivetrain with twin motors on a common shaft. I haven't seen the power rating, though.
Old 02-08-2016, 06:20 PM   #28 (permalink)
Karmann Eclectric
jray3's Avatar
Thanks Freebeard, Is that VW engine case as rare as it looks? I'm guessing freshly prepped 25 hp/ 1100 cc?
Sure, here's some of the pusher trailer exposure.
Here's an article about the pusher and its creator from Popular Science, May 2007 issue.
I've since sent the Straubel pusher on to the Historic Electric Vehicle Foundation in Arizona and am trying to have my own version ready by summer.
2000 Honda Odyssey
freebeard (02-09-2016)
Old 02-08-2016, 06:44 PM   #29 (permalink)
Karmann Eclectric
jray3's Avatar
The first 'successful' DIY hybrid I saw was a Subaru Justy with a forklift motor driving the rear wheels, which had been disconnected from the front. It was a fun hack- long since scrapped, I imagine.
2000 Honda Odyssey
Old 02-08-2016, 08:38 PM   #30 (permalink)
darcane's Avatar
"French" a motor in the driveline?
Kinda like this:
Technology | XLHybrids
There was also EchoDrive, but they appear to be out of business now.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
