09-15-2021, 12:28 AM
#111 (permalink)
マット
What are you doing to it in Michigan?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
09-15-2021, 08:58 PM
#112 (permalink)
Everything. New suspension, cleaning out the interior and restoring/replacing everything that is torn or worn or broken. Going to fiberglass or bondo the body, sand it, rebuild certain aero features (possibly the nose), possibly replace the hood and front fenders with lighter carbon pieces as the ones on it are rough, give it a nice paint job. Probably a new windshield. At that point I'll start on improving the Aero parts of Aerocivic.
The Following 3 Users Say Thank You to Ecky For This Useful Post:
09-15-2021, 10:16 PM
#113 (permalink)
Sounds good. Will you aim for new car quality or show car quality?
09-15-2021, 10:21 PM
#114 (permalink)
I'm not sure if I have the skills to reach either, but I'm going to do my best with a reasonable budget to make it the best vehicle it can be. I'm not going to hire out any body work if I can avoid it, for instance.
Maybe I'll be aiming for "well loved" from a starting point of "very tired".
09-16-2021, 12:04 AM
#115 (permalink)
There is a category called 'over-restored'.
09-16-2021, 09:46 AM
#116 (permalink)
Using just care and patience, you should be able to get to really not bad looking
09-16-2021, 09:53 AM
#117 (permalink)
マット
Maybe I should have asked, what's in Michigan that you can't do where you are currently?
I see you mentioned closing (assuming your current house), are you moving to Michigan?
1995 Mercury Tracer
09-16-2021, 10:10 AM
#118 (permalink)
That's correct. I expect to be on the ground in Michigan no later than 3-4 weeks, so I need to get the rear suspension at least put back together before then.
09-17-2021, 07:35 AM
#119 (permalink)
Too many cars
If you're driving through NY and have any problems, I can try to help.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
09-18-2021, 08:03 PM
#120 (permalink)
Made some progress! 7 or so hours, mostly with the help of an angle grinder and a sledge, and a bit of welding, and I solved every problem except the one of the bolt broken off in the chassis. I have a replacement bolt waiting to go in upon the arrival of the proper tap and drill bit.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
