Old 12-22-2010, 10:53 PM   #61 (permalink)
One of the issues I try to address in addition to low drag is stability. For a motorcycle having some down force in the front is important so I have been looking at shapes with a profile of inverted wings and a modest angle of attack. I am still at the sketching stage but I still have a fluid mechanics text to help refine things. The tendency is to use a low leading edge. On the highway the nose will need to be at the common height of bumbers and a sight line from the rider's eye to the pavement has to be acceptable.
I have been frustrated in putting pictures on EM since my camera produces jpeg files too large to post. Please use my e-mail at wgconnor@verizon.net
Old 12-22-2010, 10:56 PM   #62 (permalink)
Maybe the C-111 Mk III has gullwing wheel wells
Old 12-23-2010, 12:58 AM   #63 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Use Photobucket and you can resize the piccies through their interface.
Old 02-05-2011, 04:38 PM   #64 (permalink)
Template revision/enhancements
I was snowed in this week.I'd enlarged the template and realized how 'rough' and 'sloppy' it was so I spent some time cleaning it up and added a few features to it.
The underside reflects the SAE minimums for ground clearance.I put a chin spoiler on,and a 2.5-degree diffuser to demonstrate how the useful length is a little beyond 80 % aft-body.
You'd want to chop some of that away for license plate,lights etc.
The 10-section tail divisions have been better 'accurized'.I apologize for the sloppy work.
The Following 8 Users Say Thank You to aerohead For This Useful Post:
BamZipPow (02-08-2011), euromodder (02-05-2011), KamperBob (02-07-2011), landsailor (02-12-2011), NachtRitter (02-07-2011), NeilBlanchard (02-07-2011), t vago (02-11-2011), wmjinman (02-12-2013)
Old 02-07-2011, 01:41 PM   #65 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Thanks Phil,
I wonder if this could have helped with the Insight Tail Extension project?
Seriously, it looks really nice! I downloaded a copy.
Jim.
Old 02-07-2011, 05:48 PM   #66 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Phil, that looks great. In your mind, what kind of front wheel skirts are those?
Another random thought: how much suspension deflection should be assumed when working out your approach and departure angles?
Perhaps a moderator could copy the new, prettier, "accurized" image to the first page of this thread?
Old 02-07-2011, 06:12 PM   #67 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
RobertSmalls -
Done.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
aerohead (02-08-2011)
Old 02-07-2011, 06:56 PM   #68 (permalink)
if
Originally Posted by 3-Wheeler View Post
Thanks Phil,
Jim.
Jim,the upper curvature is the same but a smidge cleaner so it really hasn't changed.
The belly reflects what SAE would recommend for any new car design.At SAE test weight ( 300-lbs ) added to car,it's not supposed to suffer a ground strike anywhere.
We can go below it,but it's got to be 'active',with some sort of facility to 'react' to a threat and move into a 'safe' position until danger passes.
So anyway,I think what you've is basically spot-on.She's a 'LOOKER'!!!!!!!!!
I do like the EPCOT car that GM did,and at some point I'm going to do some 'active' stuff.
Can't wait for weather to improve and see how the Insight's new booty does.
Old 02-07-2011, 10:38 PM   #69 (permalink)
3-Wheeler's Avatar
Jim,the upper curvature is the same but a smidge cleaner so it really hasn't changed....
....Can't wait for weather to improve and see how the Insight's new booty does.
Hi Phil,
Well, a small piece of foam did break off the tail extension right behind the rear tire.
You know those large snow-boogers that gets attached back there? I was picking at a large chuck and it came off, but took a 1 inch square piece of foam with it.
The foam was in a spot that did not have fiberglass on it, so not too surprising really.
Anyway the wheel strakes will go right in that spot anyway when the temps rise.
___________________________
I really like looking at the new template!
Jim.
Old 02-07-2011, 10:48 PM   #70 (permalink)
3-Wheeler's Avatar
.... We can go below it,but it's got to be 'active',with some sort of facility to 'react' to a threat and move into a 'safe' position until danger passes....
Hi Phil,
I responded to this portion of your post separately since it merits emphasis....
I have pondered doing more with the underside of the Honda Insight Tail Extension to get the active angle closer to 6 degrees or so all the way back to the lights.
One big concern I have is the health of the old country roads I travel on during commutes to work. Suffice it to say they are BUMPY.
If I had a portion of the tail that simply dropped down lower than the current *hard slope*, that moveable portion would make one heck of a racket back there with all the bumps in the road.
It seems that the dropped portion would need some sort of damping, maybe in the form of soft foam rubber, or something else to cushion that constant vibration from the rough road surface.
It would be nice if the soft foam were sealed to prevent picking up moisture from the snow (or rain) when driving down the road.
Beyond that I can see using a small diameter rubber wheel to raise the moveable portion when clearing driveway aprons and such.
Jim.
Maximum angle for boat tail? abcdpeterson Aerodynamics 80 11-03-2021 12:55 PM
Aerodynamic Streamlining Template Part-B aerohead Aerodynamics 8 05-31-2013 12:23 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
Aerodynamic Streamlining Template: Part-A aerohead Aerodynamics 0 07-18-2009 02:37 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
