Old 02-26-2013, 03:14 AM   #481 (permalink)
Old but Gold - '87 Volkswagen Jetta CSL
90 day: 30.87 mpg (US)
Hi, I hope this helps some more:
Bottom, Top and Side
Volkswagen XL1 picture # 44 of 46, Technical image, MY 2014, 1600x1200
Airflow over vehicle
Volkswagen XL1 picture # 29 of 46, Side, MY 2014, 1600x1200
Old 02-26-2013, 10:52 AM   #482 (permalink)
Here's a quick and dirty comparison of the old template and the basis for the new template (blue). The fronts are aligned better than it looks. I made the heights similar to scale one to the other.
Name:	AST comparison.JPG
The Following User Says Thank You to sgtlethargic For This Useful Post:
aerohead (03-02-2013)
Old 02-26-2013, 11:05 AM   #483 (permalink)
Aligning the lengths, I see no real difference in the two templates.
Name:	AST comparison-1.JPG
Old 02-26-2013, 02:13 PM   #484 (permalink)
*I've been working with a 'modified' 'Template' since early year.
It works nicely on my latest sketches, but I still have a way to go, no matter how you slice it.
I'll be using it as my standard from now on, thanks to all who have contributed to it.
Industrial Design - Transportation Photos by kach22i | Photobucket
Did I use the top view (mirror image below) correctly?
Here is the canopy from the top isolated.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 02-27-2013, 01:54 PM   #485 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Hi,
Your new template would seem to have a length/width ratio less than the minimum of 2.5:1 set by AeroHead.
Any thoughts on how you arrived at this length?
Jim.
Old 02-27-2013, 02:17 PM   #486 (permalink)
Originally Posted by 3-Wheeler View Post
Hi,
Jim.
Does it really?
I did not check it myself.
I'd like to know how to align it, as there are several gaps making it hard to locate the high spot.
Chin Spoiler:
Roof Wing
Old 02-27-2013, 02:20 PM   #487 (permalink)
Hi,
Jim.
Hey Jim,
There is no width ("d" in 2.5d on "Aerodynamic Streamlining Template") in my sketch.
The idea was to overlay the new and old one for comparison- to see if there's much difference. Now that I think about it again, the first sketch seems correct because I aligned the heights as one would with the AST to scale it to a vehicle.
I will wait to see what AeroHead says, but I figured that comparison was a first step that could be done in an attempt to help.
Thanks,
Kurt
Old 02-27-2013, 08:55 PM   #488 (permalink)
width
Hey Jim,
Thanks,
Kurt
Thanks Kurt,I appreciate your jumping in.
I went back to the original 'Template' format,incorporating the full,2.5:1 L/D body of revolution in which the mirror-image 'Diameters' (2 X H = D) are matched,as well as the position of maximum body cross-section (Max. body camber point ).
I've ignored the 'noses' per se,as they are always discounted in Fluid Mechanics,and rather place the greater emphasis on the aft-body portion.
When I compare the old with the new,I get a very close agreement in countours,except in the initial 20% or so of the contour,where the 'new' form is a bit 'faster.'
The 'rooflines' of the two 'Templates' eventually rejoin essentially and continue on maintaining a maximum 22-degree down-slope.
I'll continue my drawings and post Saturday.
My hope is to maintain the fidelity of D&F's original curvature,without introducing any 'bumps.'
Now having worked under higher magnification,the profiles are different enough that they don't combine until within the region of ground clearance,which is cut away.The images are posted now.The top image has hash marks designating the profile of the 1st-gen profile laid on top of the new 2nd-gen.It's much as you depicted it to be.
Last edited by aerohead; 03-02-2013 at 04:49 PM.. Reason: addendum after closer look
Old 02-28-2013, 12:01 AM   #489 (permalink)
Hi,
Jim.
On third thought, I forgot about H = d/2, so I was wrong in saying there is no d in my sketch.
The template proportions should have stayed the same if/when I scaled the size.
Old 02-28-2013, 12:17 AM   #490 (permalink)
Aerohead,
Will you please take a few minutes and explain the dashed lines, especially the one I marked? I think I understand the other dashed lines to represent the top (plan) view.
Name:	AST front dotted line.JPG
Maximum angle for boat tail? abcdpeterson Aerodynamics 80 11-03-2021 12:55 PM
Aerodynamic Streamlining Template Part-B aerohead Aerodynamics 8 05-31-2013 12:23 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
Aerodynamic Streamlining Template: Part-A aerohead Aerodynamics 0 07-18-2009 02:37 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
