Old 11-02-2011, 06:14 PM   #191 (permalink)
bug
Originally Posted by Gerrelt View Post
I think at the time they developed the beetle, the 1930-tees, aerodynamics was an upcoming science. And they didn't know what we now know today.
Add to this that the beetle was developed for a TOP speed of 100 km/h, aerodynamics at high speeds as we drive today wasn't interesting.
Yes, the VW beetle was one of the first cars that attempted a aerodynamic body. But if Dr. Porsche would develop the VW beetle today, with the knowledge we have now, I think he would have reconsidered the placement of the vents.
Those cars have a "sharp" edge at the end of the roof, so seperation is easier.
Look at figure 21.23 on page 143 of the book I posted earlier ( This one ).
That edge is a trick to get the airflow to seperate at the end of the roof.
The VW beetle roof is round, making it easier for the airflow to stay attached.
Ah, I think we're talking about two different things. Those vortices are one aspect of aerodynamics, what I am talking about is what Genta calls "streamlines in the symmetry plane".
Both contribute in aerodynamic drag.
I still think the wool tuft tells a valid story and the flow is attached. If the flow wasn't attached there, the wool tufts would be going all places, and not nicely in straight lines to the bottom.
The rear of the VW beetle is not steep enough to get the flow detached, creating lift and drag. It's the same effect what caused the Audi TT to be retrofitted with a spoiler on the rear.
The effect can be seen in this picture:
Up to 30 degrees the flow stays attached, steeper then that, the flow is detached.
Maybe we should agree to disagree.
Disagreement is healthy and I always learn.
I do have a smoke-flow wind tunnel image of a Beetle in Volkswagen's wind tunnel.The smoke is departing the body exactly where Mair predicts it would.It's at the backlights upper weatherstrip.
If you will put the AUDI TT,with its rear spoiler deployed under the Template,you will see the path that smoke follows from the point of separation back to re-attachment on top of the spoiler.The TT roofline is also too steep for attached flow.
When smoke is introduced only at the vehicle centerline it can appear that the flow is good when it is not.
With respect to the 30-degree fastback,flow will be attached along the centerline only,with attached longitudinal vortices on both sides.You can correct this by pushing the rear angle up to the Template as Hucho did with the Golf/Rabbit in the wind tunnel,scoring the lowest drag.
With respect to the tufts,their orientation is influenced by vortices which can only be revealed with smoke.Their
false-signal can lull us into mis-interpreting what is actually happening in the 3-D flow field around the vehicle.
Old 11-03-2011, 05:47 PM   #192 (permalink)
123
Thinking of fiberglass VW Bug bodies. How much worse or better is this then a stock vw?
ID:	9699   Click image for larger version
Old 11-03-2011, 07:08 PM   #193 (permalink)
fiberglass
There's a frontal area advantage to begin with,as with a Karmann Ghia.
The body pictured could use a nose modification to get the air around.And the rocker panel area would be better flush with the tires all the way down and behind the rear tires.
The C-pillar buttresses could be relaxed also,lofting them closer to the Template.
It would be a good starting place.
Your car reminds me of Fiberfab's Valkerie of the early 1970s.
Old 11-03-2011, 08:42 PM   #194 (permalink)
I don't think that changing the "buttress" B-pillars will do much if any good for aero. Most of the air flowing over the car will still have that large step down to the rear deck. So to improve it you would want to have a complete cover over the "valley" there. In which case, making the slope more gradual would likely help.
Still, the drag is dependent on Cd and A, and this certainly has a large A advantage over the standard Bug body. Not sure about Cd; I would guess it is a bit better.
-soD
Old 11-04-2011, 10:50 PM   #195 (permalink)
gtkid2002's Avatar
The Bug - '69 Volkswagen Bug Base
Little free time and a few poorly spent hours with MS Paint, and here's what I've come up with for a side view. It looks like it'll fit for if I keep the body and chop the crap out of it, but I'm not so sure if this could work for the inline coupe thing. And yeah, I know the seats would almost be better off slanted. I've got no problem doing a little extra welding, but adjusting the seat might be awkward, haha.
I suck at coding! Woo!
1969 VW Bug - Daily Driver
1975 VW Baja - Current Project
Priors:
1989 Honda Prelude Si 4WS (RIP)
1995 Honda Prelude Si (Traded)
1980 Fiat Spider 2000 (Sold)
Last edited by gtkid2002; 11-04-2011 at 10:51 PM.. Reason: Forgot image code, oops.
Old 11-05-2011, 12:01 PM   #196 (permalink)
Did an overlay using a six foot tall person.
Some inspiration here:
DG-Flugzeugbau.de : DG Canopy
Sailplane Canopy Three-Wheeler
Old 11-05-2011, 12:38 PM   #197 (permalink)
Sitting directly on the floor, or having your butts poke through holes in the floor, should be worth it to get that long, low look!
Old 11-05-2011, 01:01 PM   #198 (permalink)
C not B
-soD
It is the C-Pillar buttresses I mentioned.They appear too steep.If extended, the upper curve relaxed,and plan-taper continued,they will capture a fine vortex for which the outer flow stream can bounce off,jumping to the trailing edge.
This worked fine on the CRX.
Lotus,Ferrari,Lamborghini,Honda,and Bugatti have used this to good effect,as it allows good outward vision via the vertical backlight.
Old 11-05-2011, 03:50 PM   #199 (permalink)
Smoke-flow ug photo
Here is an image of the Beetle in Volkswagen's tunnel
Caption should read Smoke-flow Bug photo
Old 11-05-2011, 04:00 PM   #200 (permalink)
The glider trike is pretty cool but they always run tires about 2x as big as they should be for some reason.
