12-10-2009, 08:41 PM
Aeroporn
The Following 2 Users Say Thank You to Eighty-Nine Si For This Useful Post:
12-10-2009, 08:50 PM
Ultimate Fail
You beat me to it.
I had a picture of this car, but never got around to uploading it.
12-10-2009, 08:58 PM
...beats walking...
...kind of a "flat" front windshield, otherwise, good attempt at streamlining.
They don't come much blunter than that!
I like the pusher prop in the back. I wonder if they were thinking of extra thrust from the exhaust heat of just filling the last bit of wake?
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
12-10-2009, 09:34 PM
I like the younger girls...
2003 Cadillac. Too bad she has 16 cylinders.
12-10-2009, 09:39 PM
...beats walking...
...from my model airplane days, I immediately thought "...ducted propellor?"
...probably a closed/sealed engine compartment with underbody air being "pulled" through the radiator.
12-10-2009, 10:39 PM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
I don't see a radiator..
12-10-2009, 10:45 PM
And Chris -- if the fan is meant to blow air back over the engine; it looks like it is mounted backwards? The curve of the blades would help them move more air if it was unbolted and flipped to face the other way...
[Edit: oh, wait, this is at the back of the car, and the fan is blowing out through the grill... The radiator is the gray-ish panel at the top of the picture (near the radiator hose!) and the whole compartment is an air plenum. The fan pulls the ait through it and blows it out the back -- putting the compartment in slight negative pressure.
It all makes sense, now...]
12-10-2009, 10:46 PM
#9 (permalink)
She's only got 16?
12-10-2009, 10:59 PM
#10 (permalink)
Neil -
Thanks! I see it now! Not sure why I didn't see it before... but I see it now.
Rather clever design... suck the air up from bad zones and use it to fill the wake behind the car.
