02-12-2013, 10:12 AM
#301 (permalink)
You are going to need to keep the hazard lights on all the time if you go though with this.
I love it, keep on truck'n.
02-21-2013, 11:02 AM
#302 (permalink)
halos.com
BZP, you might use the hitch ball mount as a support for the boattail. Depends upon how heavy you expect it to be...
The Following User Says Thank You to ECONORAM For This Useful Post:
02-25-2013, 12:49 AM
#303 (permalink)
T-100 Road Warrior
I plan on using the hitch frame as a support frame fer the lower frame work of the boat tail. It will probably be made out of 2x4 studs so it can be stiff enough to handle the air pressures. It will be solidly bolted in place so I won't have to worry about it separating and becoming a kite.
It will also provide the lower support fer the boat tail as I believe the 1"x2" wood strips won't be able to handle the air pressures back there based on my previous experience on the aero cap.
I still have a lot of brainstorming to do. It's just an idea to mull over as I don't believe it will be ready to go fer my March trip.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
11-15-2013, 08:53 PM
#304 (permalink)
T-100 Road Warrior
11-15-2013, 10:01 PM
#305 (permalink)
Termites! Hate 'em.
Was that UV damage? But it looked painted.
11-15-2013, 11:15 PM
#306 (permalink)
T-100 Road Warrior
Yup...UV damage (sun termites).
This was some old political signs. Not sure if the side I had out was UV protected or not. I did paint it with some flat black when I installed it to see if it would stop any UV degradation or not. Obviously...it didn't. I even tried some Tyvek tape and painted over that, too! That piece and the hatch piece are the only ones that have broken down so far.
I have noticed that my oldest Coroplast hasn't broken down at all...and it's originally black. It has faded over time but it's still hanging in there without becoming brittle.
11-16-2013, 12:12 PM
#307 (permalink)
T-100 Road Warrior
Did some more thinking last night and came up with a different approach on the 2x3 side support beam.
Instead of laying it down, I stood it up. This would allow me to angle the beam to better match the cab angle without a lot of cutting and shaping. Brackets on the backside would allow me to angle the beam as well as eliminate the vertical holes through the horizontal piece...which reduces the potential fer water leaks.
Support brackets...
Beam angled to match cab angle...
I'll still have to paint the 2x3 beam since it will still be exposed to water. This should reduce the amount of water rot until I move on to the next version.
11-16-2013, 01:41 PM
#308 (permalink)
UV
I worked for a fella in Lubbock during college who restored fabric and wood aircraft.After the Dacron was doped he applied the 'Hindenburg' aluminized undercoat before the color coats went on as an absolute UV block.
Many of the EAA homebuilders at Oshkosh told me that they do the same thing with their ultralites.
When I did sport parachuting we were instructed to get the Nylon canopy out of the sunlight as quick as possible to extend their service life.
Quick! Run for your lives! Solar termites are everywhere!!!!!!!!!!!!!!!!!!!
The Following 3 Users Say Thank You to aerohead For This Useful Post:
11-19-2013, 07:18 PM
#309 (permalink)
T-100 Road Warrior
Did a quick reassemble of the old parts back on the new configuration to see what needs to be addressed. Wow...I really slopped this aero cap together...just not as bad the first time.
Picked up some aluminum angle today so I can lose some weight from the hatch. Hopefully it will pan out.
I figure I should be able to use some spray adhesive to attach the template to the flashing and then trim and bend accordingly. It should prove to be an interesting start into metal work.
11-20-2013, 01:08 PM
#310 (permalink)
T-100 Road Warrior
