Old 12-19-2016, 03:48 PM   #81 (permalink)
Delta Flyer - '94 Honda Accord
90 day: 31.31 mpg (US)
With my upper and lower blocks with small inlet, the warmup time is ~2mins at35 degrees.
Hypermiling of my Own Accord
Old 12-19-2016, 03:54 PM   #82 (permalink)
True Blue - '89 Honda Civic Hatchback, 1.5ltr, 70hp, 4 spd, Base model
90 day: 47.19 mpg (US)
Shorty - '01 Mazda Miata SE
Sports Cars
90 day: 33.66 mpg (US)
Thanks for the response. What's the warmup time without?
Old 12-19-2016, 04:14 PM   #83 (permalink)
Haven't taken a stopwatch to it, but about double that at the same temperature and speed.
Old 12-19-2016, 07:11 PM   #84 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by toc View Post
Down here in Australia a grill block would only be useful to assist with warming up slightly faster, the investment of time and money into it would never be recouped in the slightly improved warm up times.
I ran a pretty aggressive grill block (~70%) on my Kangoo year round, even with 2.3-2.4 tons for that 1.6, it still beat NEDC by some margin. Grill blocks are about aero, not just warm up.
Old 12-20-2016, 08:57 AM   #85 (permalink)
Woo, thanks for all the replies guys! I guess its time to start answering them.
Originally Posted by Planecrazy View Post
Very interesting project! I have a constructive (pun intended) comment.
If the louver is made up of three pieces, why would you need the slots and retaining clips in the frame? Couldn't you simply design a frame with two holes that fit the louver pins? Once each end was in place, you could simply connect the centerpiece of the louver to the two ends and you would have a much stronger (and simpler) solution.
Hope this helps, and I will watch for versions that fit my 2010 Hybrid Milan and 2006 Hybrid Highlander! ;-)
You're quite right. I could do that. However, the one additional piece of making the clips makes assembly a lot easier. Snapping the blade together requires you slide them together length wise, not something easily done if the frame is already assembled. You could do it before the frame is assembled, and then assemble the frame around the blades. But again, it would be more difficult, especially if you have more than one blade. Also, the blade strength is pretty darn good as is (I was surprised by it), and a little glue would make it really strong.
Old 12-20-2016, 09:04 AM   #86 (permalink)
This thread is getting some newsletter attention i see... Well, my turn.
Are you interested in analog solutions to the coolant temperature input? There are lots of ways you could work around the sensor, including doing some work with the dashboard temperature indicator. That would save messing with the sensor, if you are still in the idea market.
Yep, I'm definitely open to ideas that would make it easier and/or more universal. I've thought about just taking a 1-wire or any other temp sensor, and just JB weld it to the thermostat housing. Options are good though!
Old 12-20-2016, 02:43 PM   #87 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
? Could you use an ohms type gage sending unit as the control circuit?
Explained
The servo uses a reastat for position . A '70'sGM temp sender is (if I remember correctly) 30ohms cold 120ohms hot. Or some variation of that. Put the sender in line with the position reastat. Thie would skue the position, causeing the arm to move , and the servo would think it was just holding the single point . Factory is centered.
The compleet logic /power circuit would consist of ; BEC (battery elimination circuit capable of 1 to 6s lipo in and programmable out,6v stock)servo and resistor based temperature sender.
?am I on track?
A basic bec will handle 25amps at up to 24v=6s lipo=4.2/cell@ full charge nominal .
High doller 50amp and 52v nominal.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 12-22-2016, 02:45 PM   #88 (permalink)
Took apart my 3d printer this morning real quickly since I had a bit of time. Thankfully it was super easy to find the break in the wire! A bit of soldering an it'll be back in working order, yay.
Old 01-14-2017, 06:16 PM   #89 (permalink)
Well, I got the Insight running again, so its back to this project, yay!
I took a painful ~20 minutes idling my car in the driveway today. The video showed my scangauge and a voltmeter hooked up to the coolant temperature sensor signal off the ECU. I then reviewed the video and threw the numbers into excel. I added another column to calculate the arduino input number I'll get once the arduino reads the voltage for easy programming. After 207F the fan kicked on.
Name:	Temp vs ECT voltage.jpg
The Following 2 Users Say Thank You to Daox For This Useful Post:
Ecky (01-14-2017), gumby79 (01-14-2017)
Old 01-14-2017, 07:49 PM   #90 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
Looks good, I suggest acting only in the lower 3/4 of that chart, so to stay out of the way of free cooling of the radiator.. i.e. ensure the grill block in your case is open by approx 190 deg F - by this point the thermostat should be fully open and thus the coolant actually requires cooling.. (free from airflow through radiator).
