Old 10-30-2010, 06:32 PM   This thread is in the EcoModder Project Library | #1 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Belly pan how-to
This is a thread for belly pan how-to information. I don't have the information, which is why I'm asking for it here! This thread would warrant a sticky, imho.
For anyone who has built a belly pan, can you please post some details and hopefully pics?
Here are the issues and questions I have, as I consider how to build one for my Civic:
1) Any vehicle likely needs a frame to support the belly pan from above. Has anyone built one that attached directly to the car's underbody?
2) How to attach framing and sheet material? Rivets? (aluminum or something else??) Sheet metal screws? Rubber well nuts, aka expansion plugs?? Something else?
3) What framing and sheet materials did you use? What worked and what didn't work?
4) How did you deal with the engine bay, between radiator bottom support bracket and the firewall?? Were you able to put a panel over the area, or at least over part of it?
5) How did you deal with the exhaust area? I'm considering leaving mine uncovered (it goes down the center till it gets near the gas tank) but what did you do? If car has a rear muffler, did you cover it over?
Thanks!
Coast long and prosper.
Old 10-30-2010, 09:30 PM   #2 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Well, here's one way of doing it....
http://ecomodder.com/forum/showthrea...els-10638.html
Jim.
The Following 3 Users Say Thank You to 3-Wheeler For This Useful Post:
brucepick (10-30-2010), jime57 (11-01-2010), MrMiata (11-01-2010)
Old 10-30-2010, 09:59 PM   #3 (permalink)
brucepick's Avatar
Gen-1 Insights
Jim.
Wow. Tremendous job.
Old 10-30-2010, 10:08 PM   #4 (permalink)
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
you can also have a look at the various forum links in the wiki
Belly pan - EcoModder
to answer your questions directly
Frame for belly pan: I have not used or required a frame, i am using coroplast which is fairly rigid, screwed or pop riveted at multiple points to the car body, front grill
How to attach material: I am using screws (wood screws however metal screws should be used in my case im just too cheap to get them) I am also using squares of aluminium with a hole to act as a large washer which gives more surface area to hold the coroplast to the body.
What materials used: just coroplast, aluminum squares and screws. I have also joined multiple coroplast sheets together using hot glue which works very well. (its very hard to find a really big piece of coroplast.
engine bay area: I have put belly pan material over the whole engine bay area, except where the exhaust is as it melts through the coroplast. This results in my front grill block/cover flowing straight onto the belly pan.
Exhaust area: I have left it uncovered at the moment as it would melt through the coroplast. If you are really eager you could use sheet metal over the exhaust area as it will not melt. Note: if you have any exhaust issues and any holes in your cabin area you risk having exhaust gasses feed into your cabin, you should smell that very quickly though.
The Following User Says Thank You to saand For This Useful Post:
Old 10-31-2010, 01:46 AM   #5 (permalink)
All you really need is coroplast and zip ties.
http://ecomodder.com/forum/showthrea...nder-4093.html
The Following User Says Thank You to tjts1 For This Useful Post:
brucepick (10-31-2010)
Old 10-31-2010, 02:46 AM   #6 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Here's what I've been doing with my belly pan on my Toyota T-100 truck...
The Following User Says Thank You to BamZipPow For This Useful Post:
Old 10-31-2010, 07:13 AM   #7 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
saand, you beat me to the wiki link
From my partial belly pan here is what I found. get under car and look, you should be able to see where you need one and where to attach.
Old 10-31-2010, 07:37 PM   #8 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
The belly pan is attached directly to the car's frame.
Used machine screws drilled and tapped into the metal frame and the underside of the plastic bumpers. A few attachments points in the wheel wells are screws, washers, and nuts attached through the rubbery fibrous materials used for parts of the wheel well interior wall.
Coroplast for most of the underside, aluminum flashing for the parts near the exhaust system (from front bumper down the length of the central exhaust tunnel with a bend following the exhaust pipe over to the rear right wheel).
Engine bay totally covered, used aluminum bar or angle to provide support across large gaps (engine bay, gas tank) where the car's metal frame wasn't available).
Aluminum flashing covers the extire exhaust except for the underside of the muffler where I bring coroplast to within a inch of the muffler's surface.
The Following 5 Users Say Thank You to basjoos For This Useful Post:
brucepick (02-26-2011), Cd (07-03-2011), landsailor (06-17-2011), Piwoslaw (03-15-2011), Xist (12-28-2014)
Old 10-31-2010, 08:59 PM   #9 (permalink)
Niner_xA - '05 Scion xA
90 day: 35.82 mpg (US)
Horse Hauler - '95 Ford F-250 XLT
90 day: 13.47 mpg (US)
Butterkup - '02 Mazda Miata
I have not gotten anywhere near ready to put a belly pan on my car, but I do have one product that may help. For another project, I found some self-tapping metal lathe screws at the hardware store. They've got a nice drill-style head and did fine piloting their own holes in 1/8" thick angle iron. The heads are wide and low profile, good for holding coroplast without an additional washer. They are apparently for holding fine metal lathe against the side of a house before applying stucco.
Old 11-01-2010, 12:24 AM   #10 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
Here is the link to the belly pan I made last summer. Some of it is attached directly to the subframe, but I attached wood strips and some metal cross braces to the subframe as well for extra support. A couple of the cross braces were old curtain rods. They worked but are not heavy enough. The first coroplast pan I made warped so I reinforced this pan by gluing pieces of foam board to it. This was a must for the sheetmetal pieces to keep the noise down. Panels are all attached with screws. I had to leave the exhaust open and put some fiberglass and tin flashing around the converter and front muffler to keep it from melting my pan. I haven't done a rear pan yet. Don't be afraid to spend some time laying under your car coming up with a plan. Also, don't forget to leave yourself some jacking points exposed. http://ecomodder.com/forum/showthrea...pan-13627.html
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Free belly pan in kansas city! lovemysan Aerodynamics 16 07-02-2010 10:22 PM
Air dam and belly pan wildfire8 Aerodynamics 2 05-01-2010 12:04 AM
Belly pan + Fan concept? meanderingthemaze Aerodynamics 13 02-08-2010 01:09 AM
